122(7730) ecm for turbo setup. - S-10 Forum
post #1 of 5 Old 10-13-2014, 05:51 PM Thread Starter
User is: x1991Dimex is offline
Ive gotten wind that the 7730 ECM is programmable and it is also tunable does anybody have any info on this or anything else. It cam in the 3rd gen camaros
Also.. a little off toppic. Would 1/4 plate for my manifolds work..like where the the headers mate to the block?
post #2 of 5 Old 10-13-2014, 06:45 PM
User is: The_Raven is offline
Re: 122(7730) ecm for turbo setup.
The '7730 was available in a multitude of vehicles, not just the F-body, such as Cavalier (J-Body), Beretta (L-body), etc.
There can be many different codes (programs) used the in the '7730, a couple of which are capable of using a 2 BAR MAP sensor, and one that uses a 3 BAR MAP sensor.
In my experience 1/4" plate is too thin for flanges. I use 5/16" minimum now.
The daily driver: 2005 Blazer
Tha other Toy: 1923 T-Bucket
post #3 of 5 Old 10-13-2014, 08:42 PM Thread Starter
So is that the correct ecm that ill need Raven?
I should be able to use it and have it chipped with the proper mask or whatever right?
And I have the option to go 1/2 on the flanges I can make plate at work if thatd be any better?
post #4 of 5 Old 10-14-2014, 10:40 AM
It's on of a few ECMs that will work for a boosted application.
1/2" would work, but I would use 3/8" if I had a choice.
post #5 of 5 Old 10-14-2014, 12:12 PM Thread Starter
Thanks Raven, is there any other things i nee to know with the ecm and wiring harness from the camaro that I plan to use? Im trying to gather as much info as I can before I get the engine.. im buing a complete 3.1 out of a camaro just for the intake, harness, ecm and the crank
