Why can't I roll start - S-10 Forum
post #1 of 8 Old 04-27-2019, 10:36 AM Thread Starter
Swinger's Avatar
User is: Swinger is offline
The only other 'new' stick vehicle I owned was my 02 Trans Am, god rest her soul. I can always push/roll start that. I can NOT roll start my S10. Why? At any speed at all, even a good 40mph, I'll clutch, shut off, turn the key to ON, and try and pop the clutch.....nothing. It'll actually roll in gear, without starting the engine. Why, is something screwed up with it?
Swinger is offline
post #2 of 8 Old 04-27-2019, 11:47 AM
Registered Offender
User is: Watthour is offline
Re: Why can't I roll start
I had a '96 Sonoma with the NPG-1500 and four-holer, and could only get that to roll-start maybe once out of ten attempts, second gear, ignition on, clutch drop. I never figured it out, but suspect it may be related to crank-cam timing and/or injector PW with the lack of a crank signal input from the ignition switch. I would just bump the starter for about half an engine rev and it would fire, so it was in great tune.
Frustrating, I know.
Watthour is offline
post #3 of 8 Old 04-27-2019, 01:26 PM
Registered Hoosier
Hoosier Rick's Avatar
Roll or push starting can cause damage to the cat. GM warns against it. The lack of a Vats signal is probably what prevents it.
1992 rcsb 4.3,at 357,000 miles. Rust in Peace
2002 rcsb, 2.2 at, 289,000miles
1967 C10
2006 Colorado
post #4 of 8 Old 04-27-2019, 02:02 PM
time to get cereal
manbearpig's Avatar
I used to do it in my '01, until I replaced my starter. Never had a problem.
post #5 of 8 Old 04-28-2019, 07:44 AM Thread Starter
Swinger's Avatar
Sucks, as this is my DD, and I'd like to be able to push start it should the need arise.
Swinger is offline
post #6 of 8 Old 05-08-2019, 10:57 AM
User is: ghostrider1776 is offline
I have had this issue when I had a problem with my starter. I have the best luck doing roll starting if i can get over 10 mph.
2000 S10 Base
"Humpty Dumpty"
post #7 of 8 Old 05-08-2019, 12:59 PM
User is: Century7667 is offline
Push starting the 2.2 S10 isn't easy. I attribute it to the gearing (too low), so reverse starts are just about impossible. I've managed it in 2nd, but it's a very brutal process ( kicking the clutch usually barks the tires).
Ken T.
post #8 of 8 Old 05-16-2019, 11:57 PM
User is: nstoolman1 is offline
I have tried with my 03 and it will attempt to fire but the security light comes on and it flashes.
As soon as I turn the key and start it normally, everything fires and runs normal.
I think the computer is looking for the key switch to actually get a start signal so it thinks a key is being used.
Similar Threads
no start issue BT85 262ci Forum (4.3) 7 02-02-2019 05:35 PM
s10 Hard start problem & dome light FIXED! mrjdw S10 / S15 4 06-17-2018 10:08 PM
Intermittent Crank, no start problem question/help prostuff1 262ci Forum (4.3) 14 03-01-2018 06:50 AM
Stumped no start TheReb0rnGamer 262ci Forum (4.3) 7 06-29-2016 08:34 PM
You may post new threads
You may post replies
