Stalls when idling with ac on - S-10 Forum
 3Likes
  • 1 Post By oldeerslayer
  • 1 Post By Mostizzle
post #1 of 15 Old 05-11-2019, 10:18 PM Thread Starter
User is: MichaelS10 is offline
My daughter has a 2003 Sonoma 2.2 L automatic and it stalls when the ac's on when it's idling
I was wondering where I do I start
Somebody mentioned to me it needs a new idle control valve?
Thanks
Mike
post #2 of 15 Old 05-12-2019, 07:40 AM
oldeerslayer's Avatar
User is: oldeerslayer is online now
Re: Stalls when idling with ac on
Sounds like a possibility, but be sure there are no under lying issues like DTC codes that need fixing or vacuum leaks or just flat needs new plugs and wires because it's been too long. If it runs fine, an IAC is a good starting point for throwing parts at it.
A/C? It's 30įF here as I'm typing this.
post #3 of 15 Old 05-12-2019, 08:14 AM
Jaboc33's Avatar
User is: Jaboc33 is offline
Haha yes here too. Might be obvious but if you pull the serpentine belt, is the ac pump locked up? Iíve seen this happen before when the ac clutch engages, it was frozen enough to shut off the motor.
Sent from my iPhone using Tapatalk
1999 s-10 xtreme zq8 with 1999 ls1 t-56
Jaboc33 is offline
post #4 of 15 Old 05-12-2019, 10:50 AM Thread Starter
Deerslayer and Ja I think today it's going to hit 90 degrees
Everything seems ok and ac seems ok I guess it's not going be an easy fix?
I guess I'll start with idle control valve and go from there.
post #5 of 15 Old 05-12-2019, 03:05 PM
But at least we don't have hurricanes.
Actually, here in Wisconsin we might as well have had one. The continual rain for the last 9 months caused local flooding last August and some areas are still having problems with water just a foot or two below flood stage. We've see the sun about 1 day a week since March. Must be that evil global warming that somebody is experiencing, sure ain't warm here. Right now it's solid overcast, wind out of the north (Think Arctic circle) and about 50. Definitely not mid May weather. Even for up north. Been like this since the snow ended. Two weeks ago.
post #6 of 15 Old 05-12-2019, 03:38 PM Thread Starter
Yeah it's looks the plains area and up north really had a hard winter and I guess it continues
I don't remember the snow and being cold anymore...when I visit relatives in NYC it's always in the summer!!
Texas and Louisiana have got rain bad everything is flooded!
God Bless my parents for moving to Florida from NYC when I was (I think 24 yrs old)I been down here like 35 yrs
But now I got to admit the heats getting to me never bothered before guess it has to with old age
The only time we got a really bad hurricane was Matthew 2 yrs ago or so and it was pretty fierce all the other hurricanes through the years never bothered me
Matthew blew my fence down and blew a tree over that landed on my roof I just got that taken care of
that was a lotta hassle with insurance company finally got a new tin (galvalume) roof after all that time
But we been lucky with weather as far as that goes
when my wife retires I think we gonna move to Ga or NC in the mountains we'll see
post #7 of 15 Old 05-14-2019, 10:56 AM
User is: wilvoeka is offline
GMC Envoys have that problem alot and it is the throttle position sensor 9 times out of 10, you can try cleaning the inside of the throttle body and see if that fixes it before replacing it.
wilvoeka is offline
post #8 of 15 Old 05-14-2019, 01:13 PM Thread Starter
Wil
Thanks for the advice...I will do that
I cleaned the throttle body alittle bit and it helped but I guess I need to use some Seafoam and clean it good
Thx Mike
post #9 of 15 Old 05-15-2019, 12:19 AM
Problem with Seafoam is it may loosen all that crud, but where does it go? Into the engine?
Jaboc33 likes this.
post #10 of 15 Old 05-15-2019, 08:28 AM
Chopper! Sic balls!
Mostizzle's Avatar
User is: Mostizzle is offline
lolseafoam
BravadaX likes this.
TelAmeriCorp
post #11 of 15 Old 05-15-2019, 01:33 PM Thread Starter
Hmm maybe out the exhaust??
I just was reading about Seafoam and I didn't like what I was hearing about it!
Better stuff is amsoil foam
post #12 of 15 Old 05-16-2019, 12:12 AM
Better idea is remove the throttle body and clean it on the bench. Then you can sweep the crud into the trash.
superj likes this.
post #13 of 15 Old 05-20-2019, 01:31 AM Thread Starter
Well I checked out my daughters truck today the throttle body was clean so I replaced the idle control valve (cost about $9.00 on eBay)and lo and behold the truck ran great after that no more stalling at idle with the a/c on! Dodged a bullet on that one!
Thanks for all your suggestions thanks again! Mike
post #14 of 15 Old 05-23-2019, 11:15 AM
8/31/1897 - 4/29/2004
BravadaX's Avatar
User is: BravadaX is online now
Originally Posted by Mostizzle View Post
lolseafoam
I turned mine into an Oldsmobile, bitches love Oldsmobiles.
post #15 of 15 Old 05-23-2019, 01:13 PM Thread Starter
Lol
Similar Threads
4.3 vortec smokes after idling for awhile Datones10 262ci Forum (4.3) 1 03-16-2019 10:48 PM
'90 S10 Blazer - stalls on start unless given gas Kally 262ci Forum (4.3) 4 03-09-2019 06:36 AM
rough running now not idling lazarus2297 262ci Forum (4.3) 9 03-22-2017 08:27 PM
Engine stalls after starting Ronbo4 262ci Forum (4.3) 2 05-31-2016 06:39 PM
Truck starts and stalls out within 3 secs UncleMiller Xtreme / ZQ8 2 05-16-2016 06:12 PM
