Oil pan gasket installation - S-10 Forum
post #1 of 3 Old 04-12-2019, 11:16 PM Thread Starter
User is: kourso is offline
Can somebody explain the correct way to install the 2.2 L oil pan gasket. I know you have to install the gasket with the rubber lip seal on the pan front or rear end. And do you need to put gasket sealer/RTV in both gasket sides? Thanks
kourso is offline
post #2 of 3 Old 04-13-2019, 02:39 PM
It's mostly BS
rimara's Avatar
User is: rimara is offline
Re: Oil pan gasket installation
Go to youtube and search "ericthecarguy" and search for Somoma. He does a redo of a 2.2 in several parts including the oil pan.
2001 S10 2.2 5sp ext cab
Don't hit and run...let us know how you fixed it!
rimara is offline
post #3 of 3 Old 05-16-2019, 09:55 AM
desertpatriot
desertpatriot's Avatar
User is: desertpatriot is offline
2000 S10 LSx, 2.2L , 4L60E automatic, 181K miles, Blazer brake changeover front & rear (4w abs disk), Blazer sway bars front and rear, GU6 3.42 rear end
Similar Threads
Oil Pan Gasket 2001 4.3 S10 4x4 BuzzBates S10 / Sonoma 2 09-14-2018 11:10 PM
Oil cooler lines and adapter lessons learned (1999 Blazer LT 4WD) christine_208 262ci Forum (4.3) 9 10-04-2017 11:06 PM
oil pan gasket workingdude 2.2L - 2nd gen 4-banging 4 07-17-2016 02:13 PM
oil pan gasket issues anthonycal 2.5L - 1st gen 4-banging 1 07-13-2016 03:10 PM
oil pan gasket workingdude S10 / Sonoma 0 07-11-2016 07:24 PM
You may post new threads
You may post replies
