Help me identify this bar - S-10 Forum
 1Likes
  • 1 Post By Mostizzle
post #1 of 7 Old 06-02-2019, 08:07 PM Thread Starter
User is: none0009 is offline
Hi all,
I started to hear a disturbing rattle/scraping sound when going over bumps recently in my 2.2L '95 s10. Looking underneath the engine, I noticed a ~1" diameter cylindrical steel tube that connects one side of the chasis/suspension(?) to the other was no longer properly seated and was missing a connecting nut. Anyone able to determine from my pics the the name of this so that I can start diagnosing more specifically?
Thanks!
ID:	317315   Click image for larger version
ID:	317317   Click image for larger version
ID:	317319   Click image for larger version
none0009 is offline
post #2 of 7 Old 06-02-2019, 08:11 PM
B4U Task Force
Rhotpursuit's Avatar
Re: Help me identify this bar
That's your sway bar. You're missing an end link. You can pick them up at the parts store for cheap. Just make sure it's for your truck.
Apple Red 96 SS
post #3 of 7 Old 06-02-2019, 08:15 PM Thread Starter
Thanks for the info! Much appreciated!
none0009 is offline
post #4 of 7 Old 06-02-2019, 08:35 PM
New Member
User is: dime-dozen is online now
actually that looks like the end link has been yanked thru the worn out hole.
Hole should be the same size as the shoulder on rubber.You may need to tack weld a washer onto the control arm for the rubber to seat in properly
post #5 of 7 Old 06-03-2019, 08:01 PM
Chopper! Sic balls!
Mostizzle's Avatar
User is: Mostizzle is offline
Nah, the hole is fine. You can see the large shiny area around it where the rubber isolator was.
Rhotpursuit likes this.
post #6 of 7 Old 06-03-2019, 10:05 PM
New Member
may need a better picture then,hole looks pretty beat up to me,which will eat up the rubber,then wear into the bolt.
Might be a good time to change end links to the Ford ones that Harley suggested
post #7 of 7 Old 06-03-2019, 11:17 PM
Chopper! Sic balls!
Mostizzle's Avatar
That's probably what it is...
You may post new threads
You may post replies
