Coolant Drain - S-10 Forum
 1Likes
  • 1 Post By n4hhe
post #1 of 15 Old 04-07-2008, 12:36 PM Thread Starter
fudog's Avatar
User is: fudog is offline
Coolant Drain
2000 GMC SONOMA 2.2 eng. can anyone tell me where to drain the coolant at as I do not see a petcock anywhere only a plastic plug that does not look to be removable on the bottom of the radiator. THANKS!
fudog is offline
post #2 of 15 Old 04-07-2008, 12:42 PM
xtrememeasures10's Avatar
User is: xtrememeasures10 is offline
Send a message via AIM to xtrememeasures10
Re: Coolant Drain
Should be Left hand aft lower side of raditor. There should be a little drain hose hanging down from it also that is really easy to spot if you get under the truck.
97' w/ 03' Front end, Too many mods to list....
2.2L Build and Powder Coat Project
https://www.s10forum.com/forum/f105/...ernals-486082/
post #3 of 15 Old 04-07-2008, 02:06 PM
is a fungineer
ka_jd7and1's Avatar
User is: ka_jd7and1 is offline
Send a message via AIM to ka_jd7and1
Re: Coolant Drain
The plastic plug actually is the petcock. If you get a good look at it (I just don't remember) it either pulls out and then turns, or turns then pulls out. It's kind of a pain in the ass to do, but if you can get a good look at it you'll know which way it needs to go.
Vehicles may be subject to change......
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons BLOWN UP, looking for a motor (PM me)
1968 Chevy C10 longbed, currently undergoing a heart transplant- 3/5 drop, the new tow pig/cruiser/project
post #4 of 15 Old 04-07-2008, 02:29 PM
don
don's Avatar
User is: don is offline
Re: Coolant Drain
it turns then pulls out.
--------1995 CHEVY S10 REG CAB 2.2 5speed--------
--------2005 suzuki sv650s -------
don is offline
post #5 of 15 Old 04-07-2008, 07:21 PM
User is: speed127 is offline
Re: Coolant Drain
just pull off the bottom hose that the water exits from the rad
speed127 is offline
post #6 of 15 Old 04-07-2008, 07:33 PM
don
don's Avatar
Re: Coolant Drain
Its Ezer to turn the petcock.
don is offline
post #7 of 15 Old 04-08-2008, 05:50 AM
Forum Dictator
What?'s Avatar
User is: What? is offline
Re: Coolant Drain
yup, you can use the plier, becareful, I broke mine off, got new 1 from dealership cheaper than auto zone lol, turns left to loosen and it'll pop off, if broken, try loosen and rip it off, install by pushin it in then it goes in smoother
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
post #8 of 15 Old 08-22-2008, 12:37 AM
n4hhe's Avatar
User is: n4hhe is offline
Re: Coolant Drain
Having been in there and done it yesterday, the drain plug is white nylon and has a 1/4" drive hole. A short extension on a 1/4" ratchet will open the petcock. That or a 5/16 flat blade screwdriver fits in the 1/4" diagonally and will do the job.
From the top you can see a metal pin in the nylon plug that has a bayonet like track the pin follows.
Back it out partially and it drains relatively slowly through about 1/4" nipple that some apparently have a hose attached. Drains much faster if you pull the entire nylon part out.
I found the only way I could reach the petcock was to remove the air box. That was simple enough, hose clamp on intake duct, and 10mm flange nut.
Having drained and flushed and drained all that will come out, it would only hold 6 quarts of coolant. Some places say 12, some say 14 quarts is the cooling system capacity. I might have a 50/50 mixture, and I might not. I used Peak low-tox propylene glycol, so the typical hydrometers calibrated for ethylene glycol are not calibrated properly.
So back to the original question, "Where is the drain?" Specifically where are the drain plugs on the block? 2001 2.2L.
2001 Sonoma 2.2L 5-speed long bed, stock "cheap truck"
n4hhe is offline
post #9 of 15 Old 08-22-2008, 10:12 AM
Re: Coolant Drain
Just pull your water pump off and replace it. when you pull the w/p all the rest of the coolant will come out of the block.
post #10 of 15 Old 08-22-2008, 09:45 PM
n4hhe's Avatar
Re: Coolant Drain
Sorry, I'll buy a Ford or Toyota or Dodge first.
There is a lot right with the S10/Sonoma and the 2.2L engine, but the two were clearly not made for each other.
Arclight556 likes this.
n4hhe is offline
post #11 of 15 Old 08-23-2008, 11:06 AM
User is: ivybandit is offline
Re: Coolant Drain
Lube the plastic pet cock with penetrating oil and it will not break, also re lube to close.
post #12 of 15 Old 08-23-2008, 02:59 PM
Happy with ugly truck
Buddha..'s Avatar
User is: Buddha.. is offline
Send a message via MSN to Buddha..
Re: Coolant Drain
My rad is cracked right where the petcok is. I didn't feel like trying my luck, I took of the hose. Also the tanks look like they're cracking too.
"If you wanna know something and he won't tell you, cut off one of his fingers. The little one. Then tell him his thumb's next. After that, he'll tell you if he wears ladies' underwear. I'm hungry. Let's get a taco."
If you need AC stuff shoot me a PM.
Buddha.. is offline
post #13 of 15 Old 05-18-2019, 02:07 PM
Arclight556's Avatar
User is: Arclight556 is offline
Re: Coolant Drain
https://www.s10forum.com/forum/f105/...k-plug-617562/
Arclight556
1995 S10 4cyl 2WD LS; all stock.
post #14 of 15 Old 05-18-2019, 04:39 PM
B4U Task Force
Rhotpursuit's Avatar
Re: Coolant Drain
Originally Posted by Arclight556 View Post
This thread has passed quietly to the next life...please do not disturb it.
BTW....so has the thread you linked...
Apple Red 96 SS
post #15 of 15 Old 05-23-2019, 01:13 PM
8/31/1897 - 4/29/2004
BravadaX's Avatar
User is: BravadaX is offline
Re: Coolant Drain
I turned mine into an Oldsmobile, bitches love Oldsmobiles.
BravadaX is offline
You may post new threads
You may post replies
