Calling all the kings men - 2.2L loss of power? - S-10 Forum
post #1 of 12 Old 02-05-2019, 09:23 AM Thread Starter
User is: ghostrider1776 is offline
2000 S10 | 2.2L Flex | 5-speed
Need a little help troubleshooting an issue.
Codes:
P0410 - Secondary Air Injection System
P0141 - Down Stream o2 sensor
P0446 - Evaporative Emissions System Vent (this code has been on for 70k miles. I rebuilt the engine and this is the only code I havent been able to take care of)
Symptoms: Slight loss of power under load
Advice so far: Autozone's code reader recommended to replace the SMOG pump (air recirc pump)
A little back story.
The other day I towed a small car about a mile. Kept it in 2nd and third gear.
After I did that, it felt like something was slipping but overall drove normally.
So originally, I thought I might have hurt my transmission towing as the car started to act up about 3/4 mile into the tow. Loss of power...
Last night I was driving up a fairly large hill when my truck bogged down/suffered a minor loss of power for a brief couple of seconds and then surged to normal power.
2000 S10 Base
"Humpty Dumpty"
post #2 of 12 Old 02-06-2019, 02:13 PM Thread Starter
Re: Calling all the kings men - 2.2L loss of power?
So my truck decided to start idling a little rough last night. I am likely going to replace the SMOG/AIR pump. How critical is it to use the hoses specified in the TSB?
Could a bad downstream o2 sensor cause a p0410 or would the p0410 cause the bad o2 sensor code?
2000 S10 Base
"Humpty Dumpty"
post #3 of 12 Old 02-06-2019, 06:09 PM
ΜΟΛΩΝ ΛΑΒΕ!
1fast4by's Avatar
User is: 1fast4by is offline
Send a message via AIM to 1fast4by
smog pump wont cause that...
I dont drive Chevys anymore....
1fast4by is offline
post #4 of 12 Old 02-07-2019, 01:52 PM
time to get cereal
manbearpig's Avatar
I would at least test the air pump before replacing it...
post #5 of 12 Old 02-07-2019, 03:15 PM
94 4x4,01 Blazer
Jayhawke's Avatar
User is: Jayhawke is offline
a few questions- is the cat original? have you check your exhaust for pin holes/gasket leaks- have you checked you intake/tb for gasket leaks? have you done a fuel pressure test and when was the fuel filter changed last?
32yrs of wrenching- 8 for Uncle Sam and the rest at various Garages.A bit of knowledge on everything from 2cyc Weedeaters to Jet turbines,with Civil Engineering and Computer As/Repair as a kicker.
Jayhawke is offline
post #6 of 12 Old 02-13-2019, 04:25 PM Thread Starter
Fuel pressure was 50-55 PSI when I checked last year.
O2 sensors are only a few years old.
Cat convert is a year or two old.
(Complete engine rebuild in 2015)
Got a working smog pump from the junkyard for $20. Currently running without it. Ill keep y'all updated.
2000 S10 Base
"Humpty Dumpty"
post #7 of 12 Old 02-25-2019, 10:04 AM Thread Starter
Update:
I got around to replacing the smog pump with a working one I found at junkyard. Seems to have taken care of the rough running and the various codes.
Still have a p0446 but is likely the fuel pressure sensor (ive replaced majority of vacuum hoses)
2000 S10 Base
"Humpty Dumpty"
post #8 of 12 Old 03-11-2019, 10:16 AM Thread Starter
So the p0410 came back. Replaced the check value. p0410 hasnt come back (need to check again as p0446 is my eternal PITA).
While I was in there, I noticed that the plug on cylinder 4 was loose. Tightened it down.
Plugs (ACDelco) and wires (Duralast) are new and have about 12,000 miles on. Car runs fine on flat stretches, but struggles bad on hills. I know this truck is weak on power, but it seems weaker than ever. Not getting any misfires.
Where do you think I should start?
2000 S10 Base
"Humpty Dumpty"
post #9 of 12 Old 03-11-2019, 01:12 PM
Mr Goodwrench's Evil Twin
thebadwrench's Avatar
User is: thebadwrench is offline
When was the last time the fuel filter was replaced?
14 years Professional Automotive Repair Tech. If you attempted to fix it, it will now cost you more for me to fix
My DIY Guide to OBD2 Scanners
"Blind belief in authority is the greatest enemy of truth" - Albert Einstein
"Ignorance is never a valid excuse" - Me
[SIGPIC][/SIGPIC]
post #10 of 12 Old 03-11-2019, 01:53 PM Thread Starter
Less than a year. About 12k miles ago.
2000 S10 Base
"Humpty Dumpty"
post #11 of 12 Old 04-18-2019, 01:21 PM
User is: btiberend2000s10 is offline
I had a similar situation a while ago and I went through a ton of fun. My truck would drive great as long as I didn't need to pass or put it under load. I also noticed that the voltage was dropping when I experienced the power loss. I ended up changing the belt tensioner and I replaced the little rubber grommet at the alternator clip/connection. Might be worth looking at?
post #12 of 12 Old 05-08-2019, 10:54 AM Thread Starter
Update: hooked up a scan tool and the o2 sensor was reading a constant .45v.
Crawled under the truck and found the o2 sensor wire was loose. All is good now.
2000 S10 Base
"Humpty Dumpty"
Similar Threads
suddenly runs very rough, dies, no power, runs smooth at times '02 s10 2.2L PBrooks#259 2.2L - 2nd gen 4-banging 28 01-04-2019 08:44 AM
Loss of fuel or power. TranceAmerica 2.2L - 2nd gen 4-banging 9 10-22-2018 12:25 AM
Severe loss of power, where to start? Lil'John 262ci Forum (4.3) 7 09-05-2018 07:25 PM
Power Loss Waho 262ci Forum (4.3) 10 04-11-2018 01:22 PM
'86 S10 PU 2.8L power loss off idle. Pein S10 / S15 2 04-28-2017 03:13 PM
You may post new threads
You may post replies
