ALL 2.2 Performance/Repair Info; How-To's CLICK ME!!! - S-10 Forum
post #1 of 19 Old 08-18-2005, 02:55 PM Thread Starter
The Dave Inc.
xxosiris9xx's Avatar
User is: xxosiris9xx is offline
Thumbs up ALL 2.2 Performance/Repair Info; How-To's CLICK ME!!!
Last Updated 9/28/2012
PM, contact
What?, for anything to add, update, change, anything.
Performance Parts threads!
Performance Parts List! - https://www.s10forum.com/forum/showthread.php?t=88841
Intake(Brand, eBay, Homemade, Dyno) https://www.s10forum.com/forum/f105/i...4/#post4676743
Inline Fuel Pump Install https://www.s10forum.com/forum/f105/m...lation-303943/
HP Tuner for 97-01 https://www.s10forum.com/forum/showthread.php?t=239446
Tachometer Installation https://www.s10forum.com/forum/showthread.php?t=50487
Stock Gauge Swap https://www.s10forum.com/forum/f105/stock-tach-286311/
98-03 56mm TB Mod https://www.s10forum.com/forum/showthread.php?t=93993
Performance Pullies https://www.s10forum.com/forum/f105/h...ulleys-304284/
ASP Pullies https://www.s10forum.com/forum/f105/2...esults-412780/
E-Fan Mod https://www.s10forum.com/forum/showthread.php?t=116754
Al's or OBX Header Install https://www.s10forum.com/forum/f105/h...nstall-422360/
Roller Rockers https://www.s10forum.com/forum/showthread.php?t=234639
Cavalier Intake Manifold Swap https://www.s10forum.com/forum/f105/c...7/#post4540272
Automatic Tranmission Mod https://www.s10forum.com/forum/showthread.php?t=272615
ECOTEC Engine Swap HOW-TO https://www.s10forum.com/forum/f105/t...arning-494496/
Basic Mechanical Threads!
Head Gasket Replacement https://www.s10forum.com/forum/f105/h...-steps-465392/
IAC Valve Replacement https://www.s10forum.com/forum/f105/h...cement-397867/
Timing Chain Replacement https://www.s10forum.com/forum/f105/h...-parts-368017/
Serpertine Belt Replacement https://www.s10forum.com/forum/f105/h...lation-355094/
Air Pump Replacement https://www.s10forum.com/forum/showth...75#post3547675
Alternator Replacement https://www.s10forum.com/forum/showth...55#post3220755
Clutch Replacement https://www.s10forum.com/forum/showthread.php?t=178334
98+ Coil Pack Replacement https://www.s10forum.com/forum/f105/1...p-pics-498253/
Flex Fuel sensor https://www.s10forum.com/forum/showthread.php?t=200562
Fuel Filter Replacement https://www.s10forum.com/forum/f105/h...filter-437201/
Fuel Gauge Reading Problem https://www.s10forum.com/forum/f105/i...d-this-347914/
Fuel Injector Swap/Replacement 98+ https://www.s10forum.com/forum/f105/h...to_threadtools
Governor/Speed Limiter Removal https://www.s10forum.com/forum/showth...27#post3220727
Head Gasket Replacement https://www.s10forum.com/forum/showthread.php?t=238583
Header glowing problem https://www.s10forum.com/forum/showthread.php?t=144532
Oil Cooler https://www.s10forum.com/forum/f105/oil-cooler-130715/
94-97 A/C Upgrade https://www.s10forum.com/forum/f105/s...2/#post7729967
94+ Cruise Control Install https://www.s10forum.com/forum/f105/h...nstall-497908/
Information of 2.2
Detailed Info of 94-03 2.2L
https://www.s10forum.com/forum/f105/2...-pains-321784/
Timing Chain without Tensioner
https://www.s10forum.com/forum/f105/n...sioner-502857/
Stock Camshaft Specs
https://www.s10forum.com/forum/f105/g...-guide-481955/
Valve Springs Specs
https://www.s10forum.com/forum/f105/g...c-list-446053/
post #2 of 19 Old 08-19-2009, 05:38 AM
User is: mean1010 is offline
Re: ALL 2.2 Performance Info; How-To's CLICK ME!!!
Thanks for the feedback. That is very useful.
Cheers and we look forward to your Forum Favourites selections!
plan solution commission de surendettement - commission de surendettement, vous pouvez demander un dossier de surendettement.plan solution commission de surendettement
mean1010 is offline
post #3 of 19 Old 10-30-2009, 01:26 AM
User is: kilburn is offline
were can you find a header or cam for a 2.2
kilburn is offline
post #4 of 19 Old 11-02-2009, 09:12 PM
Forum Dictator
What?'s Avatar
User is: What? is offline
Top of sticky in red font
https://www.s10forum.com/forum/f105/r...posting-88841/
OBX on eBay for header then as for cam, its basically cam regrind, easier to get stock part then take it to local machinist that does cam grind and use specifciation from link above from cam shop online.
R.I.P. Grant ('82-'02), BagNDragS10 ('80-'06), Loenuff ('66-'07), Terryl ('57-'09) Gearstix ('93-'10), Gimp ('84-'16)
If you have any problem, issue, thread/post change, request. Feel free to PM me.
What? is offline
post #5 of 19 Old 05-22-2011, 02:52 AM
User is: elipackard is offline
Where can i find torque specifications so i can put my new head gasket on, and get the engine back together?
post #6 of 19 Old 05-22-2011, 03:19 AM
Forum Dictator
What?'s Avatar
Hayne's/Chilton Manual Book.
What? is offline
post #7 of 19 Old 05-24-2011, 10:13 PM
User is: Rdn_Clean_s10 is offline
Any Tips on insulating an aluminum cold air intake? I want to try thermo tec header tape maybe it will cool down the intake.
post #8 of 19 Old 10-06-2011, 11:29 AM
98tu-tu4bangin's Avatar
User is: 98tu-tu4bangin is offline
Hi, I'm a new user and am very glad I found this site. I picked up a 98 standard cab last year with around 140k and have been driving it with regular maintence ( so far ive done ujoints, starter, plugs and wires, upgraded radio, door pins, and so on.) Im looking forward to doing the big 3, and running the efan, upgraded pulleys, 56mm tb (im gonna try to find one off a 95 buick to stay with the how to thread.) cold air intake and header. I was wondering if anyone have done all these mods (im sure there are plenty) and could post some horsepower and mpg gains, and anything else I need to know. Thanks alot
post #9 of 19 Old 02-28-2013, 04:51 PM
User is: Jdk1995 is offline
Re: ALL 2.2 Performance/Repair Info; How-To's CLICK ME!!!
Does anybody know what to tune on an efi live tun i have a 2000 ext cab stepside with a header,exhaust,gauges,and an cold air intake with 36,000 miles and have tried messing around with my stock tune but i dont know what to modify every time i try a new tune it makes it worse what do i do?
Jdk1995 is offline
post #10 of 19 Old 06-03-2013, 01:44 PM
User is: spikeytree is offline
This is what Caviler timing cover (left) looks like vs. a 99 2.2 s10 (right). During a engine replacement both the timing cover and oil pan will need to be switched. Have a nice day and hope this helps.
Name:	2013-04-22 16.16.24.jpg
post #11 of 19 Old 06-11-2013, 10:30 AM
User is: PeterUJ11 is offline
i am trying to find the stock specs on a 99 head. bought a remaned head and need it shaved down to 30 thoasandths but its already been shaved some and i need to know what stock is so i can figure out how much more i need to mill it. some help would be great. thanks
post #12 of 19 Old 08-10-2013, 02:20 PM
User is: Christophers102.2 is offline
im having a problem with my pacesetter header, it keeps throwing a o2 sensor bank 1 circuit low slow response, has any body had this problem or know what it is?
post #13 of 19 Old 01-09-2014, 05:42 PM
User is: Westly44 is offline
Hello I recently just bought a 97 gmc sonoma 2.2l and I love it it there is one thing whenever I go to try to accelerate the engine seems to rev up really high this Is only when I give it a lot of gas I know it's not going to be super fast but i believe something is wrong it's like the trangmissin just quits any ideas on what it might be .?
Westly44 is offline
post #14 of 19 Old 01-10-2014, 03:55 PM
Forever breaking this S10
NextName's Avatar
User is: NextName is offline
Sounds like a slipping transmission. Is yours an auto or a manual? If auto, could be time for a new trans or torque converter and if manual, trans or clutch.
[Mac]
2000 Chevy S10 2.2 auto
1996 Chevy S10 5spd 4x4 4.3L
96 4x4 5-speed whole truck part-out
NextName is offline
post #15 of 19 Old 07-21-2014, 09:53 AM
User is: 51_Fifty is offline
Awesome info thanks!
51_Fifty is offline
post #16 of 19 Old 12-06-2015, 03:59 AM
User is: couch22a is offline
OK I hope somebody can help me. I blew the motor in my 97 gmc sonoma 2.2l and I bought another motor just like it out of a 94 model s10. The problem I have is the crank position sensor , I cant seem to find it on this motor its not in the location of the 97? Can anyone tell me were the sensor may be and can I run my plug on my harness to it? Thank you
couch22a is offline
post #17 of 19 Old 12-06-2015, 09:50 AM
always something new
S10dude's Avatar
User is: S10dude is offline
I don't believe 94/97 will swap........
All truck pics
.......... 2014 Harley Street Glide Special ......on Air
S10dude is offline
post #18 of 19 Old 12-06-2015, 10:10 AM
2.2 Extremist
GMC Motorsports's Avatar
User is: GMC Motorsports is offline
That it will not^
It's been said time and time again. You'll need to find a 97 2.2.
You MAY be able to get a 96 to work but I can't remember exactly what was different.
I'm a bit rusty on my 2.2 info.
A 94-95 2.2 will not/can not ever work.
Same with a 98-03.
2000 GMC Sonoma SLS
ECSB 2.2L Flex Fuel L43 bored 0.40, 0.20 head shave, 5-Speed, 4.10 gears, Space Blue Metallic, Graphite Int, OBX Header, straight pipe cat delete, Thrush Welded, urethane motor mounts, ZQ8 sway bars, Hurst Short Throw Shifter, ClutchMasters 9lbs flywheel
Other Rides: 09 Canyon 5.3 ZQ8, 05 Duramax, 85 Monte Carlo SS.
post #19 of 19 Old 06-18-2018, 12:55 AM
User is: Slickdeezy562 is offline
Rebuilding my 2.2L, anybody know where I can get replacement hardware for engine and attached components?
Sent from my iPad using Tapatalk
You may post new threads
You may post replies
