AC Delco / Delphi fuel pump #'s? - S-10 Forum
post #1 of 10 Old 03-02-2019, 07:44 PM Thread Starter
Ross98's Avatar
User is: Ross98 is offline
Looking to replace my fuel pump soon, but looking around the 'net I'm seeing several different numbers for both Delphi and ACDelco, claiming to be "exact fit", "OEM". For example, FG0069 and FG0070 for Delphi, and a whole bunch of MU175x's for AC Delco. I can't see any difference, such as flex-fuel or parts that aren't in one set vs. the others.
Has anyone bought one recently? What number? I have a late-'98 VIN 4 engine. TIA!
1998 S-10 Ext cab/2.2/5-sp
Ross98 is offline
post #2 of 10 Old 03-03-2019, 02:28 AM
TranceAmerica's Avatar
User is: TranceAmerica is offline
Haven't bought one lately but I heard ac delco bought Delphi back awhile ago so its probably the same quality cross check part #s. Check rock auto, the best way to make sure you're getting the correct part is to call you local Chevy dealership parts # with the last 8 of your vin so you can confirm you're getting the correct part for the truck a lot of times under part types for make model of vehicles listed at Auto Parts suppliers the parts might look similar but they're actually not going to fit your truck sometimes . That's in the same thing that says OEM Direct Fit and it's the wrong part because of variations in trucks. Or you can go to the parts manufacturers website and some of them have a look up by your VIN like gmpartsdirect is one of them for example.
post #3 of 10 Old 03-03-2019, 07:10 AM
oldeerslayer's Avatar
Re: AC Delco / Delphi fuel pump #'s?
DELPHI FG0069 or ACDELCO MU1756 are the only numbers that I saw listed on Rockauto for a vin4 1998 s10 pickup.
Where were you finding different numbers? The Delphi FG0070 is for a 97+ 4.3 V6, not your Tutu.
I'm sure if you are looking at these you are aware that GM upgraded the electrical connector on these and a new one comes with either pump.
They include some crimp butt connectors. Throw the but connectors away as they are not weather tight and shouldn't be used on a connection under the vehicle. Solder the connections and wrap in marine grade shrink wrap. The kind that has sealant inside that melts and fills any gaps when you heat it during installation. That method is weather tight. If you want to OCD it use 2 layers of shrink wrap. The inner just slightly longer than the exposed wire and then a second layer about 1- 1-1/2" longer over top of the first to double seal it.
Some folks are confused by the orange wire on the new connector. It connects to the orange/black sensor ground on the original wiring. The other 3, just match the colors.
post #4 of 10 Old 03-03-2019, 12:12 PM Thread Starter
Ross98's Avatar
Thanks for the replies. Where I was seeing a discrepancy was between Rock Auto, AutoZone, and Advance Auto. I'll check with gmdirect, good idea.
In a search on here, the ACDelco number someone recommended was a MU1754, which is different than what Rock Auto is showing.
Ross98 is offline
post #5 of 10 Old 03-03-2019, 12:27 PM
B4U Task Force
Rhotpursuit's Avatar
I've had better luck with the Delphi units. The gas gauge is very responsive to vehicle movement.
Apple Red 96 SS
post #6 of 10 Old 03-03-2019, 12:50 PM
Post Whore
chevymec's Avatar
User is: chevymec is offline
Delphi all the way. I've found with a lot of units from the dealership, they do not come with the level sensor and the cost goes up after purchasing that also.
1997 SS---Built and Blown... almost
My build thread... https://www.s10forum.com/forum/f30/pr...ecs-ss-513887/
chevymec is offline
post #7 of 10 Old 04-14-2019, 01:56 PM Thread Starter
Ross98's Avatar
So I was checking out the situation, trying to decide between tipping the bed up, and dropping the tank. When I got underneath, I saw that the hose clamps on the filler hose and the vent hose to the filler tube are both worm-gear clamps. I assume GM would have used those single-use crimp-on clamps at the factory? I'm thinking the tank has been out before, for a fuel pump replacement. I've been planning to replace the pump "just because" it has 160K on it, PO's records didn't list a FP replacement. But he also didn't list a timing chain replacement, and I can clearly see where someone had the cover off (RTV all over).
Am I assuming correctly about the clamps?
Also, I see on Youtube where guys simply lift the front of the bed up, with all but the rearmost bolts out, and those loosened. Sure looks like the bottom/front of the bed would hit the cab unless the bed is also slid backwards?
Ross98 is offline
post #8 of 10 Old 04-14-2019, 02:55 PM
94 4x4,01 Blazer
Jayhawke's Avatar
User is: Jayhawke is offline
bed flips up just fine- apply heat to bolts- hit with impact or Long Handle socket wrench or pipe and socket wrench- dopping tank a ***** and DO N0T cut the bed.... , ps all bolts out and unbolt filler neck at the gas door- then you can tilt or flip the bed up .
32yrs of wrenching- 8 for Uncle Sam and the rest at various Garages.A bit of knowledge on everything from 2cyc Weedeaters to Jet turbines,with Civil Engineering and Computer As/Repair as a kicker.
Jayhawke is offline
post #9 of 10 Old 04-14-2019, 03:07 PM Thread Starter
Ross98's Avatar
Originally Posted by Jayhawke View Post
bed flips up just fine- apply heat to bolts- hit with impact or Long Handle socket wrench or pipe and socket wrench- dopping tank a bitch and DO N0T cut the bed.... , ps all bolts out and unbolt filler neck at the gas door- then you can tilt or flip the bed up .
So ALL the bolts need to be out? That actually makes more sense, it would allow the bed to move back. Thanks for the reply!
Ross98 is offline
post #10 of 10 Old 04-14-2019, 08:32 PM
Lifelong S-10 Owner
67Truckin's Avatar
User is: 67Truckin is offline
Send a message via MSN to 67Truckin
I took all the bed bolts out and moved the bed back a couple inches. Then put it on some 4x4 blocks for extra room to work under it. Only takes about 30 minutes once the bed is back out of the way.
Built... not bought. Scars to prove it.
Similar Threads
Replaced bad fuel pump and now wonít start jdomke1 S10 / S15 18 01-27-2018 09:20 PM
AC Delco fuel pump problems big gear head S10 / Sonoma 3 10-13-2017 11:57 PM
PCM swap problem Rhotpursuit 262ci Forum (4.3) 83 07-11-2017 03:19 PM
2000 S10 No Start, No Fuel Pump Prime Signal stonecutter 262ci Forum (4.3) 14 10-19-2016 08:43 PM
