2000 gmc 2.2 flex fuel engine swap - S-10 Forum
post #1 of 3 Old 03-26-2019, 09:21 AM Thread Starter
User is: Scottsha1080 is offline
I've got a 2000 gmc with the 2.2l flexfuel engine. It needs to be replaced and all I can find locally is a 2000 s10 2.2 that is gasoline. What will I need to take off my motor in order to complete the swap without having to change the computer?
post #2 of 3 Old 03-27-2019, 01:37 PM
It's mostly BS
rimara's Avatar
User is: rimara is offline
Re: 2000 gmc 2.2 flex fuel engine swap
The Flex injectors are different. Keep your manifold and fuel rail to work with the flex system. Also, at some point, they did away with the EGR valve system not exactly sure when. If the new one has the EGR, discard that and use your old block off plate on the back of the head. Use your exhaust manifold and gasket to work with your truck's AIR system.
Not sure how this got in the Flame section.
2001 S10 2.2 5sp ext cab
Don't hit and run...let us know how you fixed it!
rimara is offline
post #3 of 3 Old 03-27-2019, 03:41 PM
B4U Task Force
Rhotpursuit's Avatar
Moved to 2.2
I didn't notice it was in Flame...thanks.
Apple Red 96 SS
Similar Threads
Engine swap Yowakawaka S10 / S15 1 02-28-2019 01:58 PM
non flex fuel truck with flex fuel intake Steve Lee 2.2L - 2nd gen 4-banging 9 09-26-2017 05:07 PM
PCM swap problem Rhotpursuit 262ci Forum (4.3) 83 07-11-2017 03:19 PM
2.2 swap and differences between years simardfosgate3 2.2L - 2nd gen 4-banging 3 04-21-2016 08:53 PM
