Cast iron exhaust manifold - S-10 Forum
 2Likes
  • 1 Post By twag4
  • 1 Post By Mad Max
post #1 of 5 Old 04-06-2019, 12:28 PM Thread Starter
User is: twag4 is offline
Bit the bullet and ordered this yesterday. Itíll be here Tuesday. Iím hoping itíll take care of my exhaust leaks. At 65000 miles, my oem manifold gave it up. I bought a tube type replacement that wonít stay sealed. Itíll go a few weeks then start leaking at the gasket again. Iím hoping this does the trick once and for all.
twag4 is offline
post #2 of 5 Old 04-10-2019, 02:56 PM Thread Starter
Re: Cast iron exhaust manifold
Installed, and no leaks. Those cheap soft steel tubing manifolds canít do that!
BravadaX likes this.
twag4 is offline
post #3 of 5 Old 04-15-2019, 09:25 PM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
I bought one of those. The outlet was just under 1 3/4" - hardly enough to allow exhaust out.
I sold it right away.
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
Mad Max is offline
post #4 of 5 Old 04-17-2019, 09:56 AM Thread Starter
Mine is fine! It doesnít have the pipe sticking out like the stock one, but the donut gasket works fine, and no leaking. The outlet diameter is actually slightly bigger than the small diameter outlet pipe of the oem style manifold. So the restriction is the donut gasket, which normally fits over the outlet pipe of the stock manifold. Mine should actually flow a little better. The last one I bought, oem style, cracked after 7 months. It always leaked though, even with trying two gaskets, metal and layered gaskets, Tick tick tick. No more. Iím happy with this, it is fantastic compared to the other junk that is out there. Had it been a little narrower output, Iíd have just dressed it with a die grinder anyway.
twag4 is offline
post #5 of 5 Old 04-17-2019, 08:28 PM
Boozebag
Mad Max's Avatar
There are a few different brands out there - that I have seen - I must have pruchased on of the crappier ones.
Great to hear that it solved your problem.
twag4 likes this.
S10 addiction:
Mad Max is offline
Similar Threads
WTD Iron Duke Performance Intake Manifold rdavisinva Wanted, to Buy 1 03-06-2019 07:16 PM
Iron DUKE Exhaust 2.5 long tube header & complete exhaust pixelmonkey Engine 10 05-08-2018 07:32 AM
1996 S10 Ext Cab 4.3L right side exhaust manifold Sumtxguy 262ci Forum (4.3) 3 12-03-2017 06:39 PM
Some LS info .... long post!!!! Wkeracing LSx Discussion 3 08-10-2016 05:41 PM
You may post new threads
You may post replies
