4x4 transmissions to mate to 2.5l 4 cylinder ? - S-10 Forum
post #1 of 5 Old 04-24-2019, 08:55 PM Thread Starter
User is: Autzen Buchanan is offline
I currently have a 5 speed in my 85 s15 and my 3 and 4 gear are going bad. I'm looking for a replacement 4x4 transmission to put it, anyone know of any? Names of transmissions?
post #2 of 5 Old 04-24-2019, 11:13 PM
I'm super serial
manbearpig's Avatar
Re: 4x4 transmissions to mate to 2.5l 4 cylinder ?
A 2.8L has the same bellhousing pattern, should work? A T5, I assume.
post #3 of 5 Old 05-02-2019, 12:27 AM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
You will need a 4x4 transmission. They don't have a tail shaft housing and bolt directly to the Xfer case.
I think that you can convert a 2x4 to 4x4 by disassembling the tranny and retro fitting the output shaft. Don't quote me though.
MBP is correct. The 2.5 and 2.8 interchange.
BUT.... if you think a 4x4 (5) speed is rare, try finding a 2.5 (5) speed 4x4. There are a few members who have them, but they are about as common as a white deer.
Good luck finding one used. RARE!
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
Mad Max is offline
post #4 of 5 Old 05-02-2019, 12:56 AM
Racer-X's Avatar
User is: Racer-X is offline
Try http://car-part.com/
You might need to make several calls for that one. The yards that list parts on that site rarely keep their inventory up to date. I can usually find what I'm looking for after a half dozen calls or so, more if the part is rare. That site doesn't seem to differentiate which engine, making the list even more difficult to deal with.
The bolt pattern is the same on the Iron Duke and the 2.8L V6, but isn't the starter on the opposite side? Or are they interchangeable? Something in my possibly faulty memory tells me that the bolts will go in, but the starter won't fit properly.
You might be able to use one of the 4.3L V6 ones if you swap bell housing sections.
Racer-X is offline
post #5 of 5 Old 05-02-2019, 02:32 AM
Harley's Avatar
User is: Harley is online now
The T5 is also not too bad to fix up if the gears aren't tore up and it's just the synchros. I've had my fair share apart, but getting the preload setup correctly is probably the biggest challenge I faced.
Similar Threads
4x4 issues 88cyclone S10 / S15 5 01-03-2019 03:21 PM
4x4 Questions buddy94 Transmission & Rearend 6 03-15-2018 09:11 PM
Weird 4x4 problems BackwoodsPatriot Transmission & Rearend 4 09-05-2017 12:20 AM
Hydraulic clutch master cylinder jwvess-- Transmission & Rearend 2 01-03-2017 07:18 PM
Some LS info .... long post!!!! Wkeracing LSx Discussion 3 08-10-2016 05:41 PM
