Starting issues - S-10 Forum
post #1 of 12 Old 04-21-2019, 12:23 AM Thread Starter
js1974's Avatar
User is: js1974 is offline
Starting issues
I just picked up an 83 s10 over the winter with a carbureted 350 in it. The truck will start if I have a jumper box on it but wont without it. The voltage will drop from 13s to 5 while it is cranking then go back up to 13 when I let off the key. I replaced all thr connections at the battery and a new ground wire to the block. It will crank but acts like dead battery. As soon as I put the jumper box on it it will fire right up. I've tried 3 batteries and all the same results. Could it be the starter draining too much or a wiring issue?
Thanks in advance.
js1974 is offline
post #2 of 12 Old 04-21-2019, 05:31 AM
94 4x4,01 Blazer
Jayhawke's Avatar
User is: Jayhawke is offline
Re: Starting issues
check the rest of the grounds- sounds like the coil is not getting enough power while cranking , and check the cable ends(under the plastic) at the battery
32yrs of wrenching- 8 for Uncle Sam and the rest at various Garages.A bit of knowledge on everything from 2cyc Weedeaters to Jet turbines,with Civil Engineering and Computer As/Repair as a kicker.
Jayhawke is offline
post #3 of 12 Old 04-21-2019, 07:07 AM
oldeerslayer's Avatar
Re: Starting issues
Is the battery relocated with too small of a cable? Does the ground go directly to the block?
post #4 of 12 Old 04-21-2019, 08:48 AM
2003 S10 4.3 Stepside
User is: aleekat is offline
aleekat is offline
post #5 of 12 Old 04-21-2019, 02:40 PM Thread Starter
js1974's Avatar
The battery is in the original spot,I just put a new 4 guage wire about 2 foot long to the engine block. I checked with my meter and without cranking the ground from the battery to the block reads 0.00 and while cranking it jumps up just a little .
js1974 is offline
post #6 of 12 Old 04-21-2019, 09:51 PM
Re: Starting issues
Same on the positive side? If so, then probably the starter. Or that engine is very hard to turn over for some reason. Try putting a socket on the front crank pulley. It should rotate with a moderate amount of force. You'll feel the compression stroke of each cylinder as increased resistance, but it should still rotate w/o using a long bar and a pipe,
post #7 of 12 Old 04-21-2019, 11:44 PM Thread Starter
js1974's Avatar
The positive side drops from 13.? Down to 5.? When its cranking. I'll have to try a bar when I get home. The guy i got it from said it does have a different cam if that makes any difference.
js1974 is offline
post #8 of 12 Old 04-22-2019, 07:05 AM
Re: Starting issues
Did he say which cam or the specs? Shouldn't really make that much difference.
Test the resistance of the positive cable w/o power. It should be nearly nothing.
post #9 of 12 Old 04-22-2019, 07:49 AM
94 4x4,01 Blazer
Jayhawke's Avatar
Re: Starting issues
pull cable ends of starter- check voltage, then disco battery and check resistance- should be full voltage/ near zero resistance- drop starter and take to parts store and have checked- while apart- clean cable ends- if starter good- check contact bolts for rust and clean. make sure you have ground wires from rear of block (2) to firewall. also check batt to frame ground.
Jayhawke is offline
post #10 of 12 Old 04-22-2019, 07:10 PM Thread Starter
js1974's Avatar
I put a ratchet on it and it turns but takes alot to move it.
js1974 is offline
post #11 of 12 Old 04-22-2019, 07:37 PM
B4U Task Force
Rhotpursuit's Avatar
Re: Starting issues
It's going to take some effort since you're going thru the compression cycles.
Apple Red 96 SS
post #12 of 12 Old 04-22-2019, 11:01 PM
Re: Starting issues
If you can turn it with some effort with a ratchet, that sounds about normal for a 350. Drop the starter. I've seen a lot of swaps where the PO thought he needed to install some super starter off ebay. A good OEM late model starter works better IMHO.
Similar Threads
Starting issues 89statics10 2.5L - 1st gen 4-banging 4 03-14-2018 10:57 AM
Issues starting, accelerating, and backfiring Clean95 262ci Forum (4.3) 1 07-20-2017 07:29 AM
Three Recent issues with my truck...any guesses as to what the problems could be? Krissy Wheels, Tires & Brakes 1 07-10-2016 01:23 PM
