Fuel pump for tbi - S-10 Forum
post #1 of 4 Old 05-21-2019, 08:23 AM Thread Starter
User is: RiverCity is offline
Fuel pump for tbi
I have a 2000 s10 with a 2.2. I had planned to use the stock fuel pump with the TBI and a pressure regulator.but the existing pump is dead. Does anyone know if a 87-93 in tank fuel pump will fit a 2000 tank. I really didn't have much luck with an inline fuel pump last time I did a v8 conversion. Thank you
post #2 of 4 Old 05-22-2019, 08:45 AM
oldeerslayer's Avatar
Re: Fuel pump for tbi
I would think a 94 vinZ tank and pump would bolt it.
Why a TBI on an 00?
TBI 350's are good solid engines. Just no HP.
post #3 of 4 Old 05-23-2019, 01:30 PM Thread Starter
The engine ran a low 14 with a stock auto in a camaro with 2.70 ? ratio. I want a cruiser that gets 25mpg that can run high 13s low 14s.
post #4 of 4 Old 05-23-2019, 02:56 PM
User is: Juntao_Dw is offline
the sending units that my tbi truck used is an old school metal one spectra part number fg06a, not sure if you can adapt the pump which is a delphi fe0115 into your current sending unit. Also if you intend on using the older unit i'm not sure if it'll fit into your tank. I've checked with harris performance's website he list some mods and things you can do to spruce up TBI injection. He always recommends upping fuel pressure to a higher pressure pump a delco ep381 which flows 155lph 62psi *ish. i suppose if the 2.2 pump can match those numbers i don't see a reason to change it out. On my truck i'll be running an ep381 and an 18lb regulator spring on stock injectors it should have an injector flow rate of 72lbs/hr should withstand 340 hp that should be plenty.
Similar Threads
Fuel Pump Question FirstGensForever LSx Discussion 7 10-08-2018 10:21 AM
Replaced bad fuel pump and now wonít start jdomke1 S10 / S15 18 01-27-2018 09:20 PM
PCM swap problem Rhotpursuit 262ci Forum (4.3) 83 07-11-2017 03:19 PM
2000 S10 No Start, No Fuel Pump Prime Signal stonecutter 262ci Forum (4.3) 14 10-19-2016 08:43 PM
