ive seen plenty of irocs on s10's and blazers so it should work no problem. i have 20x8.5, +10mm offset, 245/40-20 and a big brake kit in the front(adds like 1/2" to the track width) in the front and 20x9.5 0 offset 275/35-20 in the back. had to roll fenders front and back but it tucked nice.
ya my stock irocs fit well . but my tires rub the quarter lip. i shaved them but need to shave a little more. and this is the back im talking about. for the front i have to cut the inner fenders to clear.
now i need to get some different tires for my stock irocs for now and going with a smaller sidewall.
hopefully this spring ill pick up a set of 20" irocs or boss338 i think that's the number..
as i like both. ill have to save some money if i can to get them. unless i can find a set of used ones.
just trying to figure out what people are using and if what you have clears .
whats the wides i can go in the front?
as i want it the same front to back. well maybe a little wider in rear, maybe..
At first I did want the 9.5 in the front too, but I was worried about turning radius and hitting the fenders, Bcuz the drop spindles push the wheels out a lil, and since it's a s10 the big brakes push it out alil too.
Now I'm Sfbd it, the fronts seem perfect but the rears might hit the bedside.
