The SS was introduced in 1994. About 2756 (rough est.) SS's were made a year.
They were each equipped with the 4.3L V6 producing 180 hp and on up to 195 hp Stock!
That's more horses than anything in its class. It thrashed the Ford Ranger Splash,
and that was pretty much its only competition. The SS was introduced with only
three colors: Onyx Black, Summit White, and Apple Red. . In 94 and 95, the SS came with 15" cast aluminum wheels, and chrome center caps and red bowties. SS badging and fog lamps were standard equipment as well. The rear-end was a 3.42 limited slip gear. This gave the SS an awsome advantage at stop lights. In 1996 the SS took on a new look. The ZQ8 suspension was upgraded to 16x8" wheels borrowed from the early 90's model RS and Z28 camaros. The over all suspension was also dropped 2" giving it a lower stance and more aggressive feel for the road. YEARNUMBER PRODUCED19945,67019951,61919961,24019971,4591998UNAVAILABLEThese numbers were given directly to Ronny (97 SS owner) from Chevrolet.
You can contact CHEVROLET'S main office at 1-800-222-1020 for any information.
This is the Only Wheels that were offered in 94 and 95. This is a 95 SS, as was said before, there weren't many distinguishing characteristics about the SS as you can see.
This is the badge that is located on every door and tailgate of every SS. No other (stock) S-10s have these.
1994-1995 Specs
Engine typeV-6 OHV, 2 valves/cyclinderDisplacement ci/cc262/4293horsepower195@4500torque260@3600axle ratio3.42:1base curb weight2905 lbs.fuel cap20 gals.fuel economy ,city/hwy17/24suspension (f/r)independent/line axlewheels15x7.0inch, cast aluminumtires215/65r15 BF Goodrich Comp TAacceleration (0-60)7.9 secs1/4 mile sec/mph16.1 85.0braking(60-0)140 ftslalom(600ft)60.1 mphskidpad (200ft).79 g's
1996-1998 Specs
*Grill and Interior upgraded in 98*
Engine type 4.00x3.48/101.6x88.4 Bore x stroke, in/mm4.00x3.48/101.6x88.4Displacement, ci/cc 262/4293 Compression ratio9.2:1 Valve gear OHV, 2 valves/cyl.Fuel-induction system Sequential fuel injectionHorsepower, hp @ rpm, SAE net180 @ 4400Torque, lb-ft @ rpm, SAE net240 @ 2800 Horsepower/liter40.7 Redline, rpm5600 rpmTransmission type4-speed automatic (ONLY) Axle ratio3.42:1Final drive ratio2.39:1Recommended fuelRegular Unleaded1996-1998 Chassis
Suspension, F/R Unequel Length Control arms, coil springs, anti roll bar/live axle, leaf springsSteering type, ratioPower recirculating ball 15.0-13.0:1Turning circle, ft34.8Turns, lock to lock 3.0 Brakes, F/RVented disc/drums, ABSStock Tires Goodyear Eagle GA235/55HR161996-1998 Performance
Acceleration, sec. 0-302.70-404.40-506.40-608.70-7012.00-8015.9Standing quarter-mile, sec./mph16.1/82.03Braking, 60-0, ft 148Lateral acceleration, g 0.82Speed through 600-ft slalom, mph69.0 mph EPA fuel economy, mpg, city/hwy 17/23Est. range, city/hwy, miles 323/437
