spintech prostreet exhaust s10
Old 08-12-2008, 03:56 AM   #1
VBitter is on a distinguished road
Hello, I have a 2002 extreme, and I want to change out the stock exhaust system for the spintech prostreet muffler. I have 1 question though, I also want a high flow cat...whats a good brand for one? Also, what else do I need to buy for the setup, before taking it to the muffler shop? Any help would be great.
Old 08-12-2008, 04:19 AM   #2
Re: spintech prostreet exhaust s10
what is the part number for the magnaflow high flow cat for the extreme? oh and the spintech part #? anyone know?
Old 08-12-2008, 02:14 PM   #3
SoCal Football
bg's's Avatar
bg's will become famous soon enough
Spintech sells cats as well. Though with a 2002 that cat
which comes on it is a hi flowing unit too.
Old 08-12-2008, 02:25 PM   #4
Master's Apprentices
MINTSICK's Avatar
MINTSICK is on a distinguished road
I used a spintech hi flow cat with a spintech sportsman street on the truck I list in my signature, both were of high quality and sounded great.
Old 08-14-2008, 01:06 PM   #5
bump up.
Old 08-14-2008, 02:54 PM   #6
Its a Blue thing.
Mr Blue's Avatar
Mr Blue is on a distinguished road
http://www.spintechmufflers.com/spin...ntechindex.asp
Old 08-14-2008, 06:24 PM   #7
Mikz86TA's Avatar
Mikz86TA is on a distinguished road
The shop I had my exh done used a Magnaflow Univ Hi-Flo cat. They welded it in.
Later models (including my 2003 and your 2002) have the cat(s) as a part of the y-pipe assembly. If you went to GM and bought the replacement cat, it would come with the y-pipe. From the exh manifolds (2 3-bolt flanges) to the flange just behind the big cat (1 2-bolt flange.
I had a custom y-pipe mad and removed the pre-cat.
Before that tho, I had my stock cat go bad. I had them weld in the Magnaflow unit and they reused it when my y-pipe was done.
The part number was 94037. Magnaflow Hi-Flo cat. You can buy that anywhere.
Dynomax, Magnaflow, Spintech, Dynatech and others make replacement Hi-flo cats.
The stock ones flow really well tho. If yours isnt bad, not much sense in replacing it. That Mag unit does have an additional port (plugged right now) for another 02 sensor....if you added a AF Gague that would be a cool benefit.
Hope this helps/shines some light
Old 08-15-2008, 05:35 PM   #8
Starting from scratch...
02_Black_XBlazer's Avatar
02_Black_XBlazer is on a distinguished road
I've had good luck with my Magnaflow hi-flow uni cat as well. Like Mikz86ta said, the part numbers that have one or more 02 bung(s) included are helpful for obdII compliance for plugging in the rear o2, or like he said, using as a spot to set up an A/F guage if an o2 sensor is not needed there.
Page generated in 0.12381 seconds with 11 queries
