pre-cat - S-10 Forum
pre-cat
Old 07-10-2010, 07:42 AM   #1
charliepickup22's Avatar
pre-cat
hey i'm planning on removing my precat how do get over the x-member ? i also wanted to remove the flat section of pipe. i thought of a flex pipe but not sure if it would work.
Old 07-12-2010, 12:36 AM   #2
firebird77's Avatar
Re: pre-cat
Pics?
And usually the cross member is dropped if it is in the way of exhaust components.
Old 07-12-2010, 06:58 AM   #3
Re: pre-cat
no camara ! but from what i can explain it's about 2.5 tube maybe less it sits in between the cross member goes a bit flat goes over the x-member goes normal again and connects to the cat converter. remember this is from the pre-cat to the cat.
