long vs. short headers? - S-10 Forum
Old 11-12-2003, 06:09 PM   #1
no power
454ss's Avatar
what are the pros and cons?
im planning to rebuild my 91 4.3 and was wondering which to get. i have my eyes set on hedman #69400.
Old 11-12-2003, 06:23 PM   #2
Project: Sabriel
MuddyS10's Avatar
as far as i know, there are no true long tube headers for a 4.3 the long tube increase torque and hp, and the shorties increase hp at the expense of torque. or maybe i have that backwards....
Old 11-19-2003, 09:57 PM   #3
mrgtbike's Avatar
You want more low end go with short headers, more top end with longer headers...
Old 11-19-2003, 10:37 PM   #4
no power
454ss's Avatar
is that hp or torque?
Old 11-19-2003, 11:42 PM   #5
mrgtbike's Avatar
HP
Old 11-19-2003, 11:43 PM   #6
mrgtbike's Avatar
its a trick used by nascar, short headers on the short tracks, for more low end, and longer on the superspeedways, more top end, can be a difference of about 15-20 hp depending on how many inches difference in the length
Old 11-19-2003, 11:56 PM   #7
no power
454ss's Avatar
ok what is better for torque?
Old 11-20-2003, 08:38 AM   #8
mrgtbike's Avatar
I'm not to sure about torque....I'm more concerned with my get up and go rather than my pulling power, I have a duramax if I need to pull stuff....but i would assume that headers either way will give you an increase over regular exhaust manifolds
Old 11-21-2003, 12:14 AM   #9
Derrick824's Avatar
If you end up wanting the Hedmans, I've got a brand new set of long tubes, part# 69400, sitting in the shop that have never been installed. PM me if you're interested.
Old 11-21-2003, 02:37 PM   #10
Registered Loser
Sketchy's Avatar
Shorties - Less weight, better low end torque and some mid with a lil high end.
Long Tubes - SOTP through the WHOLE range. BUT, about twice the weight...hah, maybe not that much, but quite a bit more. Also, LT's usually have less ground clearance.
Hope it helps!
Sketchy
Old 11-21-2003, 06:11 PM   #11
no power
454ss's Avatar
i decided to go with the hedmans.
Derrick- thanks for the offer but i already got some off of ebay
and thanks for the info guys
