FLOWMASTER knock off? - S-10 Forum
post #1 of 15 Old 04-12-2011, 04:29 PM Thread Starter
User is: 1994ricers-10 is offline
Exclamation FLOWMASTER knock off?
ok guys, on my previous posts i have asked for a cheap nice sounding muffler for my 1994 chevy 2.2L s-10 and some of the peopl wanted me to make huge modifications when i only wanted a muffler suggestion. anyways i went out and asked different muffler shops for a cheap nice sounding muffler and these are the ones they mentioned
magnaflow- installed $125
Flowmaster- installed $100
Cherrybomb turbo- installed $70
Flowmaster (probably 40 series) - installed $60 . . . . <- sounds like a knock off flowmaster right?
does anyone know or have any experience with knock off flowmasters? do they last? are they bad? any insights please
2.25in off set muffler in and output and 2.25 piping with a 2.5in, input and 3in output chrome exhaust tip..... just trying to get my fix it ticket written off
Thanks guys
post #2 of 15 Old 04-12-2011, 04:49 PM
Project 99 Problems
racermike450's Avatar
User is: racermike450 is offline
Re: FLOWMASTER knock off?
knock offs are just as good when you buy flowmaster your buying the name
post #3 of 15 Old 04-12-2011, 05:01 PM
Warheads on Foreheads
Z06killinsbf's Avatar
User is: Z06killinsbf is offline
Flowmasters sound like garbage on 4 bangers. I have a dumped Magnaflow and it sounds pretty good. Also look at Pypes brand mufflers
Also, stepping up to 2-1/2" pipe will have a deeper sound
post #4 of 15 Old 04-12-2011, 09:19 PM
JustAnSS's Avatar
User is: JustAnSS is offline
My brother had flowmaster knocks offs on his drag truck (Flowkings). He eventually got some super 44s and guess what? They were identical! He never had problems with them. My other brother is also running knock offs on his car, no problems yet.
Personally I would go with magnaflow though. It is the quietest out of the bunch and flows the best. Can't go wrong with magnaflow.
JustAnSS is offline
post #5 of 15 Old 04-13-2011, 01:03 AM
a mintruck is never done
sonoma2bdifferent's Avatar
User is: sonoma2bdifferent is offline
im runnung a knock off flowmaster ,does great ,supusedly came from the same building as flowmaster, just no name stamped in it
post #6 of 15 Old 04-13-2011, 04:36 AM
clearly_canadian's Avatar
User is: clearly_canadian is offline
thrush welded on mine......look like flowmaster and sound decent.
post #7 of 15 Old 04-13-2011, 01:20 PM Thread Starter
If anyone lives in california, do you guys know if the flowmaster 40 series on a 2.2 s10 is legal... under 95 decibels (dB)?
post #8 of 15 Old 04-13-2011, 02:39 PM
2.2 Extremist
GMC Motorsports's Avatar
User is: GMC Motorsports is offline
if your still running a cat, which I'm sure you are, you should be fine as far as noise goes,
2000 GMC Sonoma SLS
ECSB 2.2L Flex Fuel L43 bored 0.40, 0.20 head shave, 5-Speed, 4.10 gears, Space Blue Metallic, Graphite Int, OBX Header, straight pipe cat delete, Thrush Welded, urethane motor mounts, ZQ8 sway bars, Hurst Short Throw Shifter, ClutchMasters 9lbs flywheel
Other Rides: 09 Canyon 5.3 ZQ8, 05 Duramax, 85 Monte Carlo SS.
post #9 of 15 Old 04-13-2011, 03:02 PM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
The patent for Flowmaster ran out a while back and they didn't renew it for some reason. All of a sudden, there were a ton of knock offs on the market. I'm pretty sure each knock off brand opened a Flow and copied it with a small change to make it just slightly different. I had one on a Ford Courier with a HOT 2.3 Ford engine in it, sounded pretty knarly.
The knock offs look almost identical to the Flowblaster.
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
2) '85 S10, 3.4, 700R4 4x4 stretch cab (Redneck) 3) '90 S10 2.5, 5 speed shorty
6) '83 S10, 327, TH 350, shorty (13.00 best)
7) '92 S10, 2.5 5 speed, Shorty
8) 1979 LUV, Buick 3.8 V6, TH 350 Shorty.
Mad Max is offline
post #10 of 15 Old 04-13-2011, 05:10 PM Thread Starter
ok i just got it done . . its much quieter but i wish i would get a little more sound out of it.. . how can i post pictures here so i can show before after?
link to before video --->
post #11 of 15 Old 04-13-2011, 05:10 PM Thread Starter
deleted duplicate post
Last edited by 1994ricers-10; 04-13-2011 at 05:13 PM. Reason: i dont know how to delete duplicate posts i made in accident
post #12 of 15 Old 04-13-2011, 05:10 PM Thread Starter
post #13 of 15 Old 04-13-2011, 05:11 PM Thread Starter
post #14 of 15 Old 04-13-2011, 05:11 PM Thread Starter
post #15 of 15 Old 04-13-2011, 05:11 PM Thread Starter
