Do it yourself o2 simulator
After a search I found that http://www.rodney.chalker.com/o2_simulator.htm
had a way to make your own o2 simulator. However, that site is down and I was wondering if anyone has those directions or know how to do it using a resistor. |
Re: Do it yourself o2 simulator
I will put it this way if you need new 02 sensors than buy them. Don't try to override them unless you have LS1 Edit and can eliminate them from the computer. If your computer has to read the 02 sensor don't try to make your own. You can't rig it up with a resistor.
Well i don't need new o2 sensors. I need an o2 simulator because I have a straight pipe in place of my cat. I've read before on the website I linked on how to make one but I can't remember how to and the site is down.
Ok I thought you said O2 sensor. The simulator is like $15 from Casper Electronics. Just buy one.
Gaaoooooo
Sprint Car Addict.
link to this site??
Starting from scratch...
btw, I know someone will yell about gravedigging an old thread, but kudos for using the search button.
is a fungineer
![]() Age: 27
Dunno for sure if this will work for an S10, but:
http://www.mkiv.com/techarticles/oxy...sor_simulator/ Assembly diagram and parts list is included. |
joining 2.2l boosted club
I can get the splice in type from PYPES for a mustang, the operate basically the same. Anybody know which wire I gotta hack into?
Yes, I know this is an old thread! |
It works, and there is no need to cut any wires or anything...very easy as well.
I personally have driven about 300 miles since, no CEL. So anybody who wants to run a test pipe...here is the mod you should do to stop the CEL...don't bother with the electronic ones with only some of them working...and not working all the time. These pics are from it being done STi, but I did it on my S, works just the same. ![]() ![]() ![]() or ![]() Those are the Spark plug, Anti-Foulers you'll need to do this..just pick them up at any auto parts store This post has been edited by SLO-S2000 on Aug 21 2004, 11:11 AM |
i did this on my 03 civic si and i never got a check engine light. also did it on my bros acura.
bowties in my bloodstream
I'm gonna do this sometime after spring break when i get some spare time. The CEL is really gettin on my nerves being on constantly..
Nevada: Hookers & Poker
Did the non fouler to my truck about 2 weeks ago and it works perfectly
Tech Mod
![]() Age: 25
Did this to my truck 3 weeks ago also and it works perfect. My high flow cat was throwing the P0420 code every now and then, sometimes it doesn't throw that code for months then out of nowhere it pops up, other times it pops up every few drive cycles. I still have the stock cat and i was about to put that back on there because i got tired of deleting the damn code (kept the obdii reader in my truck lol).
Since i threw the O2 foulers on, bam, no SES light. |
its easy mmmkay
so this acually works? but u cant gut ur cat and do this right?
Ive had that set up on my acura for over a year. It works great, its an easy 6 dollar fix to the check engine light.
out draggin.. brb
sry to chime in here with question but i too have a test pipe handy and would love to use it. so is all thats being done here is putting 2 non fowlers together and then putting the o2 into them, creating a larger gap between the cap/test pipe and o2?
out draggin.. brb
answered my own question and doing it today..
Tech Mod
![]() Age: 25
from what i read online you can run a test pipe and it still wont throw the code. as long as the O2 sensor sees the heat then it wont throw the code.
Just to be 100% in a couple of days post it up if your light has or hasn't come on yet. |
Ok i've got the spark plug non foulers, and i'm looking at them and went to look for a 1/2" drill bit today... is there another form of a 1/2" drill bit? the one i found was freakin huge... like about the same size as the circumfrence of the non fouler bottom...
Tech Mod
![]() Age: 25
yeah... i got mine drilled out at a friends shop, he put the 1/2 bit on a lathe and it was close to the threads. you can almost see the indentation of the threads after you drill it out, barely any metal left... |
Alright as long as i make sure it's right... my stepdad has a uni-bit we can use, i'll probably do it tomorrow while we already have the truck up to do my calipers.
#24 |
I attempted to do this tonight, I drilled out the fouler using a 1/2'' drill bit, and my o2 sensor doesn't fit in it. Anyone have an idea?
#25 |
idk but how long does it usually take to bore out the fouler? Maybe i'm doing something wrong? I got the 1/2 drill bit and started to bore it out but after like 10 minutes of drilling in it on and off i had to quit(mostly to not be sweaty when i picked up my girlfriend), but i mean the hole in the middle didn't get any bigger but the actual surface of the fouler where i was drilling did get much thinner so maybe just go at it a little bit more with it? I knew i shoulda bought that damn unibit...
#26 |
To answer my own question, the stock 02 sensors are larger than .5'', I had to buy aftermarket, and it works flawlessly.
As for drill time, about 5 min. I worked my way up to a 1/2'', make sure the bits are for metal too btw, and not wood. Having a nice vice is key for getting it done quick. |
#27 |
I have a straight pipe. I have the non-fowlers on my as well with no light. My budy didn't believe it worked so he did it to his lexus is300....worked as well.
#28 |
man i don't feel like spending any more money buying another bit trying to bore this thing out. I tried with the 1/2" bit and the surface got deeper but the hole didnt get any bigger and i don't think it's making any more progress no matter how much i go at it. So i guess the CEL is just gonna stay off, at least until i can get to a better set of tools
#29 |
Tech Mod
![]() Age: 25
Take it to a machine shop, they can easily bore it out more.
with mine i had it bored out to the stock o2 sensor size, the aftermarket i had in there went in with alot of room to spare. |
#30 |
I think all i need is a unibit but it's 17 bucks at lowes and i really dont wanna buy that shit. My new rollpan should be here soon and when i take it to my dads shop to be painted and put on and have my door panel and window fixed, i'll use his unibit up at his shop to finish the o2 simulator. I asked him to bring it home a few times but the guy never remembers haha
#31 |
S-series abuser
Ive been using the non foulers for quite a while now on my 96 2.2l. Havent had any issues.
#32 |
wow, i had done this about 2 years ago, posted on here, did get that much responce.....and today i see someone else post about it and get tons of responces......and yes it does work, my check engine light was on do to a hollowed out cat, did the non-fouler trick whent for a drive the check engine light whent off by itself...im not runnin it anymore do to new motor, and no the motor was still running when i pulled it out, just wanted a little more power. and im also obd1 now.
#33 |
i did this last thursday but my light is still on. think if i get the code cleared it will keep it off? still contemplating getting the sime from afterthoughts auto
#34 |
Farmin in Iowa
Wow here is an old thread
#35 |
Put a high-flow cat on and threw a code after. Just did this today , ive driven the truck for a good hour after clearing the code and no code yet ! I will post in a couple days to confirm . This is an awesome trick
#36 |
that guy
ok which one did yall use the 42002 or the 42009 ?
#37 |
Tech Mod
![]() Age: 25
42002 i believe. the packaging looks familiar.
oh and its still working for me
#38 |
terrible. take a lap.
what exactly is this used for? having a bad 02 sensor? or not having a cat? or having a straight pipe through the cat?
#39 |
Dig Or Die=I Die
#40 |
Dig Or Die=I Die
When you remove, gut, weld a straight pipe through the cat or install a high flow cat this code is thrown. It's basically saying that the cat isn't working. If anyone is having a problem drilling the hole in the non-foulers. You're doing something wrong. I drilled mine out with a 14v cordless De Walt in my kitchen using a ratchet and socket to hold it. Also! For those that notice after drilling out the tip on the o2 still wont fit because it's a tad bit wide in diameter than 1/2". Mine didn't either. This is what I did. Just take some pliers or channel locks and bent in the little vents/fins on the o2. Then the stock o2 will fit. It's not like it matters if you screw it up. You're basically deleting the thing anyways. You don't have to buy a after market o2. I didn't. ![]() Before^^^^ wont screw on. ![]() ^^^^^Drill, drill bit, non foulers and what ever you wanna use to hold it still while you drill it. The non foulers or aluminum and real easy to drill. You only have to drill one deep enough to get the o2 to screw all the way in which is like 1/4-3/8". ![]() ^^^^ drill that deeper. ![]() ![]() ^^^^This is how I held it. ![]() ^^^ Drilled deeper and screwed on. ![]() ^^^^Doubled up for safe measure. I don't think 2 is needed but WTH? 2 come in a pack anyways... |
#41 |
well then, lol...i got a magnaflow hi flow cat too...i wonder if i should just not bother with the cat and just gut out my stock cat even though the stock exhaust is what, 2.25? and then just bump the muffler size and call it a job..?
#42 |
forum idiot
yep did the spark plug non fouler thing...not a issue..
#43 |
Foot buried in it
Why gut the cat instead of just deleting it all together?
#44 |
forum idiot
#45 |
Foot buried in it
#46 |
Dig Or Die=I Die
#47 |
Foot buried in it
You guys are awesome.
#48 |
**** yeahhhh!!! im buying one of these,and ill just give my mom my magnaflow hi flow cat since she needs a new cat anyways... ill call these guys tomorrow and see what they can do about an 02 sensor bung ![]() 12sws27 you're the man! lol |
#49 |
So just to be clear.....removing the cat and putting a straight pipe in its place will trip the CEL, but will it hurt\damage anything else? My check engine light has been on forever, and I don't really care about it if that's all that will happen.
#50 |
forum idiot
yes...but if it is throwing a CEL for a o2 sensor it may run shitty..once i did this fix the truck runs better and has better pick up on the highway..same shitty gas mileage
| Sponsored Links | |
Advertisement | |
