CRMB Y pipe installed 2001 auto, looking for ppl to step up
Old 07-12-2008, 02:55 AM   #1
Tacklin Fuel
BLACKBOWTIESS10's Avatar
BLACKBOWTIESS10 is on a distinguished road
I am going to post some pictures of it when I get the chance, but for now I will explain what I ran into and what I think we, as a group, can do. Seriously
2001 S10 ZQ8 Auto Ext cab 4.3
Ok, first off I'd like to say I'm impressed with the look of the y pipe. Very nice.
The fit however, is completely off, which is ok for a test run...to be expected.
The alignment into the pre-cat was off and the O2 bungs were as well.
So I told the exhaust shop "make it work and do it right"
So needless to say it cost me a small fortune to have it modified. But it looks good. I removed the pre-cat when the pipe went in, I wasn't going to have that thing still there after all this.
At the same time (80k miles) I had them replace the spark plugs, wires, cap, rotor, and front 2 O2 sensors. Knowing this, my gains will be distorted some because I have changed other things at the time of Y pipe installation. Having said this… I really like the difference. I don’t feel like I lost anything on the bottom end. If I have, it’s not noticeable enough to me to complain. However, the way the truck breathes after 1000rpm is great. It drives very nice and responds to throttle input better. Even cruising at a low 45 mph, with the trans in OD lock, the truck feels stronger. It will pull a lugging gear easier than before. The freeway manners are nicer as well. I feel like my throttle input is “lighter” on the gas pedal. WOT is improved as well, it just pulls easier. I can’t wait for my lake trip coming up, I want to see how well it tows now.
Now, I don’t know if this has to do with the tune up or the Y pipe, could be just the tune, dunno. However, it drives very nice, and sounds really really good. I run a 50 series flowmaster single in single out with an over the axle dump. I went this route (this time) cause I wanted a mellow sound that didn’t annoy me. At the same time, when at WOT it sounds good and not hollow. I also already knew my Y pipe was going in sooner or later, so the muffler would be a good match for the pipe and minus pre-cat. It sounds great, a deep mellow and throaty sound. It revs faster now and sounds so damn cool. Great combo FYI / IMO. Next year will be my first smog check here in CA with the pipe and minus cat, hopefully it should do fine as long as they don’t look hard.
Ok, here is what I’m willing to do and what I think others might be willing to fall in line for. Since no one wants to travel all that distance on there own, for free, I say we start a fund. I now have a CRMB Y pipe modified to fit a 2001 auto. It has only one clearance issue that should be worked out by CRMB for any future production. The pipe is really close to the trans pan and I plan on putting header wrap on the pipe in this one location about 1ft across. Since my truck in only a zq8 and wont be getting any lower, ground clearance was never an issue for me. Having said that, the pipe does hang down some, maybe the same as stock, maybe a shy bit more, dunno. I know pictures will help, hang on they are coming soon.
What I am willing to do. I will drive to Oregon from Los Angeles only if I get some help from those truly interested in helping this project out. It’s about 1000 miles one way for me, but I am serious about taking the drive only if I get help. A 2000 mile round trip, using a truck that gets an average 17-21mpg will run about 100 gallons of gas. 2000/20=100 Which 4.50 a gallon = 450 bucks. I would be willing to chip in like 20 bucks. It doesn’t sound like much, but I’m already paying for my own hotel. I will also be taking off work, which might be planned anyway since my foot is screwed up. I’ll prolly site see while they are using my truck. Only problem I can see with them using my truck…is that I don’t have a pre-cat anymore, nor the location it used to be in. I do have their y pipe and u can clearly see where the collector ends.
Dunno, but before I keep chattering on and possibly wasting my time, I’ll wait for some replies. I promise pictures within the next couple of days.
Old 07-12-2008, 02:56 AM   #2
Tacklin Fuel
Re: CRMB Y pipe installed 2001 auto, looking for ppl to step up
O, and I've got a 180 T-stat and PCM tune going in soon. muwahaha hehehe
Old 07-12-2008, 09:31 AM   #3
Will work for turbo parts
King_Ice_Flash2 is on a distinguished road
Not many of us are looking to keep the pre-cat, since we were looking for a more performance oriented y-pipe than the Magnaflow.
I am willing to send some money your way. What are we looking at? $20 each?
I am still trying to figure out what I am going to do, because I bought one, and right now, the weather is too bad to have downtime with the truck and FedEx lost my Argon tank. I could also make mine work and mail it to him.
Thanks for stepping up and doing something.
Old 07-12-2008, 10:55 AM   #4
Tacklin Fuel
^^ This is what I wanted to do as well, modify it and then send it his way. Unfortunately all my stock stuff is in the trash, so I can't go back. Plus the pipe is welding in place permanently, so it would need to be cut out and then reinstalled after they use it for measurements. I have a feeling the pipe will help a lot, but just having a truck there might be the best.
Can I get some pictures of STOCK y pipes on vehicles between the years 97 and 2003. This way I can compare my 2001 and see just what years my truck will be helping. Or if anyone works in a dealership or knows someone, can you pull up part numbers and compare? If I were to guess, 1999-2003, but guessing at this point has become stupid and not worth anything. Send them to DirtDevilBT@yahoo.com.
And $20 each from those that were on the "I'll buy one" list would be perfect. I'd also think anyone contributing should be at the top of CRMB's list once production is restarted. $20 from the folks with the same truck as mine sounds fair enough. If you don't care about the y pipe I use, maybe we can start multiple funds and have a fund for each year/tranny/cleanance of pipe. Then let those funds go to other members with those types of trucks.
I think Paypal would work best, even though the fees suck. Maybe a middle man between me and the funds would keep folks happy. I dunno how to make this any more "trustable". It's people sending me money to do something. Not long ago there was a scam on my ATV forum, so I understand not many people like these kinds of ideas. I can't say or do anything to MAKE any of you feel secure about this, so I'm all ears as to what you want to do.
Old 07-13-2008, 05:56 PM   #5
Tacklin Fuel
a crap load of pictures
the pipe hangs down just past the trans mount bracket
I don't have a picture of the stocker. I'd be curious how far it hands down.
I also came across something looking at the pictures, lol I'm missing a nut for the exhaust. I'll have to talk to them about that. I took a video for sound, but it didn't come out well. I'll try later some time.
Old 07-13-2008, 05:57 PM   #6
Tacklin Fuel
Old 07-13-2008, 05:57 PM   #7
Tacklin Fuel
Old 07-13-2008, 10:03 PM   #8
With the exception of the R o2 sensor, looks like it fit to me...
Old 07-14-2008, 12:12 AM   #9
Tacklin Fuel
nah, the O2 sensor fits good, can't go much to either side to get any better, maybe but not much.
both were relocated to fit once on the truck
still lovin it, sounds narly
Old 07-14-2008, 02:33 PM   #10
civil's Avatar
civil is on a distinguished road
Pics of a stock y-pipe clearance. Trucks dropped 5/5
looks like its about the same clearance.
Old 07-14-2008, 02:41 PM   #11
-119 point(s) total
sonomanator's Avatar
sonomanator is infamous around these partssonomanator is infamous around these parts
i wanna hear this y pipe the exhaust shop that did my exhaust said they could build me a y pipe but im curious how it will sound and performs.
Old 07-19-2008, 09:38 PM   #12
rusty bumper member
HofinaterSS's Avatar
HofinaterSS
could the shop ovalize the pipe so it would be tucked up more? Wouldnt lose any flow, just flatten it out a bit..
Old 07-20-2008, 09:11 PM   #13
I finally got blown
99xtrm's Avatar
99xtrm
i guess im in to paypal you some money what do we need to do, start a sign up sheet then all of us paypal you the money all at once, i would say either ask for a little bit more like 25 or take a little bit more people, that way there is something in it for you instead of you just breaking even.
if you want to do the sign up sheet thing i guess ill start it, then everyone after me can copy and paste and just add their name to it
1. 99xtrm
Old 07-20-2008, 10:22 PM   #14
yellow035speed is on a distinguished road
1. 99xtrm
2. yellow035speed
Old 07-21-2008, 02:43 AM   #15
Tacklin Fuel
a sign up sounds good all
my truck is a 2001 s10 auto ext cab
20 bucks needs roughly 25 ppl
25 bucks needs roughly 20
that's splitting 500 bucks up I guess
I'll throw my hat in, even though I already have one
PS> thanks for the pictures civil, that's awesome. And my truck is on blocks currently, was doing the front brakes until no shops around here could turn my rotors, now I'm driving around the spare for a couple days. So, in a couple days I will have some decent sound clips for you.
1. 99xtrm
2. yellow035speed
3.Blackbowtiess10 (Brent)
Old 07-21-2008, 10:59 AM   #16
"Da Dog"
greatdane68's Avatar
greatdane68 is on a distinguished road
Hey, let me know when they start producing this Y-pipe and for how much. I may go ahead and buy one. I'll just put it away until I get the truck that I want.
Also, send some pics of the production piece to me once they have one.
Old 07-21-2008, 02:24 PM   #17
civil's Avatar
1. 99xtrm
2. yellow035speed
4. civil
Also: wanna put up your paypal account so i know where to send it? thanks.
Old 07-21-2008, 08:30 PM   #18
Always workin on somethin
neal2's Avatar
neal2 is on a distinguished road
1. 99xtrm
2. yellow035speed
4. civil
5. neal2
Let's get the ball rollin'.
Old 07-22-2008, 02:02 AM   #19
Tacklin Fuel
before I put my address up I'm going to call CRMB and show him this thread. I want to make sure he is actually still interested before any of you or I get carried away with this. I don't want any of your money until I know he will welcome me. So, I'll get back to Uzz guys. Tomorrow I'll have sound.
Old 07-29-2008, 12:05 PM   #20
not low enuf
slowrider1983's Avatar
slowrider1983 is on a distinguished road
is this like a group buy for the y pipe?
Old 07-29-2008, 11:31 PM   #21
Tacklin Fuel
no^^
Here is a quick video for sound. It's not that great but you can just make out the note difference with the pipe. It is much deeper and rumbles like it should. I do have the pre-cat removed. Sounds great IMO. This is with a 50 series Flow, not a spintech or some louder Flow etc. I apologize for the traffice noise, I was coming back from the lake and took the video while coming home, instead of at my house where my neighbors would sport confused looks out their windows. But, you can hear it in the last two parts of the video. It is metallic sounding, I like it but might not be to the taste of some. You can hear it best on the last part, where the camera is in the back. In the very beginning of each rev, you can here a note, definitely not stock hehe. Love it, the note is heard only under load....like WOT 1st and 2nd...then it's gone.
Old 07-29-2008, 11:33 PM   #22
Starting from scratch...
02_Black_XBlazer's Avatar
02_Black_XBlazer is on a distinguished road
http://www.s10forum.com/forum/f89/y-...happen-306388/
Old 07-30-2008, 03:23 AM   #23
hammer dawn's Avatar
hammer dawn is on a distinguished road
bad ass man my budy is makeing me 1 and taking out my pre-cat, and i allready have an exhaust cut out after the main cat so its going to sound so mean ... hahahaha but good work on the y pipes bro. and good pics!!!!!
Old 07-30-2008, 04:09 AM   #24
"Da Dog"
Man, that sounds damn good!!!
Old 07-30-2008, 06:21 PM   #25
Unregistered User
j894's Avatar
j894 is on a distinguished road
what about gains from the pipe?
Did you gain any High RPM power?
DId you loose any low end?
Does it not feel held back when you romp on it now?
Old 07-31-2008, 06:40 PM   #26
Unregistered User
j894's Avatar
Hey, I was just talking with CRMB..
everyone who's interested in this 4x4 Pipe should call about it.
They are making a run of them in the next few days so they have to know how many to make. The ones already made are spoken for.
Old 08-02-2008, 01:01 AM   #27
Tacklin Fuel
gains = I wouldn't know exactly
High rpm = yes, it revs easier, quicker, and stronger, where as before it fell on it's face after 3k rpm.
Lowend loss = none, it pulls higher gears easier and starts from a dead stop just the same
WOT feel = great, it continues to pull where as before it fell off in the upper range. It also pulls a trailer a little easier, a little easier, it's not a v8 now.
While it's nothing amazing, it is a very nice change. You're not going to smoke tires or accelerate so fast the needle blurs, but it does seem to breathe easier and rev out nicer. Call me crazy, but it when it revs high, it might be a little smoother (ie: vibrations).
Old 08-02-2008, 03:46 AM   #28
Unregistered User
j894's Avatar
You answered my question perfectly thanks.
I can't wait to get my 4x4 pipe although Im waiting for them to call me back as to when they make the next batch? ( a few days maybe?)
I think I know what your talking about with the "vibration" seems after 3000rpm with the throttle wide open it has like a kinda buzz/vibration(dont know how else to describe it), that's not there when you rev it under load whereas you aren't fully opening the throttle.
Old 08-08-2008, 01:46 PM   #29
civil's Avatar
any updates on this? did ya get ahold of them? any word at all?
Old 08-09-2008, 10:58 PM   #30
Tacklin Fuel
Quote: Originally Posted by civil
any updates on this? did ya get a hold of them? any word at all?
I'm running 14 hour days at work right now. I've been dropping by to see if there are any replies. It's quite depressing to see how many people drop off the face of the earth as soon as they are asked to step up. Throughout the Y pipe thread, there were people deciding to stand by and wait for updates, wait for people to buy the pipes and reply. That's fine, I bought one and ended up having to modify it, because I didn't want to sit aside and do nothing. Now that there have been some people reporting back, good and bad, this project is still possible to finish. However, those that stood by, seem to have disappeared, quite possibly never intending on helping in the first place.
I read all about spintech, flows, headers, etc...but not too much about y pipes and I've got to say, that stocker is terrible. I've got about 350 bucks into this thing ( y pipe, modifications, install) and it's done. I can sit back with pen in hand, and check this mod off. Then, you'll never hear from me again, and this thread vanishes like a fart in the wind. Later, a new thread posing the same questions and ideas will be started, and the cycle continues. If you don't like the pipe, go with an Eldelbrock TES system and modify it to accept air injection. Or for those without smog, don't. There are ways to do it, I chose to keep the stock manifolds and smog because I'm in CA.
Someone will need to call up CRMB for me and ask. I most likely will not be able to for some time since I don't get home till long after the shop closes. I'm also pretty busy during the day to make the call, I prolly could, but why? I am not going to beg or coach people into hopping on board this thing. After all, I've asked several shops to make this y pipe, I've talked with CRMB, I've excepted the challenges and did what I could.....I'm done and moving on to the next mod.
