Yet Another Mr. Clean AutoDry
Old 07-06-2004, 12:32 PM   #1
Derek@2020Kustoms's Avatar
Alright here is yet another review of the Mr. Clean AutoDry.
I picked the starter kit at Canadian Tire for $28.99 (Canadian). The process is pretty simple as many other reviews have noted. First I filled a bucket of water with my Meguiars car soap. Then sprayed down my truck with normal water to get it wet. I then used the soap dial on the mr clean to spray down one area with its polymer soap. I then used my mit and bucket as I normal and wash the area. Then I sprayed down like normal with NON filtered water. I basically did half my truck like this. Because it was hot out, once I got half way, I then used the FILTERED water went over the areas I already cleaned. I did this because you don't want the NON filtered water to dry, which will leave spots. So once I finished washing the entire truck, I went over it with the FILTERED water. Let it dry and be amazed. This product really does work.. I have a black xtreme and was amazed. I read reviews that a few water sports in hard to get areas were left but I never seen ANY. I must admit I went over the entire truck with the filtered water for a good period of time to make sure no regular water was left on the truck (which I believe is the key)
The starter kit has a water filter that last 3 washes (or it sais). The polymer soap in the starter kit probably only lasts 3 washes also. I am curious if the polymer soap is required. It claims it helps sheet off water. I think I will attempt not to use the soap next time to see how it turns out.
Overall: This is an excellent product. I found it still look me the same amount of time from start to finish as it normally does, but the results are better in the end. I won't be using anything else to wash my truck.
Old 07-06-2004, 01:00 PM   #2
PaintRush's Avatar
Re: Yet Another Mr. Clean AutoDry
The entire key to the "water sheeting" action is the soap itself. It has an ingredient in it much like Jet Dry. It's a water softening agent which allows the water to not dry on your car and leave spots.
The filtered water is the last bit of the system that is needed, since the water is so clean, it doesn't really "grab on".
Old 07-07-2004, 02:48 AM   #3
Forvm Lurker
anALLSHOx's Avatar
that sounds pretty cool...but i still doubt it would work here in vegas, the water basically evaporates as it comes out the hose!
Old 07-07-2004, 02:53 AM   #4
has committed suicide!
Got-20z's Avatar
either way it might work great but i don't know about you guys but i usually was my truck 3 times within a 2 week period..i can't afford that shit every 3 washes
Old 07-07-2004, 10:27 AM   #5
www.myspace.com/MINTSICK
jmwxtreme43's Avatar
i've been using the same filter since i got it, still seems to work fine, although i switched soaps and left a little more spots then than i saw with the mr.clean soap, but i dont want to buy that stuff cause its so damn expensive!
Old 07-11-2004, 03:31 PM   #6
SVT Cobra Moderator
Offthehook's Avatar
its still cheaper than bringing your car to have it washed
Old 07-11-2004, 06:25 PM   #7
dixie highway destroyer
xbrightsidex's Avatar
it is cheaper than taking it to get washed, and it does work pretty well.
i found one on sale at target around here for 15 bucks, and i had a $5 coupon for it. go the whole thing for 10 bucks. i'm impressed at how well it works. i still hand dry my windows, and i squegee excess water off my bed cap, but other than that, very minimal water spots. (the cap's too flat to let water drain off easily)
i use eagle one soap in my mr. clean. still works great. i like to mix a little of their "wax-as-u-dry" stuff in with the soap too. makes it a bit shinier every time i wash.
Old 07-11-2004, 08:28 PM   #8
The Beast
baggedime's Avatar
I hear ya, it gets a little ridiculous here in Phoenix too. It's almost 5:00 and it's still 110 out. I'd like to try this thing and see if it works. How much is the soap and filters?
Old 07-13-2004, 09:35 PM   #9
'Stevie Joe'
HighrollerII's Avatar
yea, i can vouch for it to that its an excellent product...the soap and filter replacemants are about $6 each.
Old 07-13-2004, 10:23 PM   #10
JHart666's Avatar
i agree i loved it... just a hassle to me changin soap and such
Old 07-13-2004, 10:27 PM   #11
GMtruckHQ
kevincolin's Avatar
The Mr.clean soap is just thinner. And the reason it sheets off is cuz the water you wash it with is "soft", like in a dishwasher, softwater leaves less spots then hard water.
Old 07-14-2004, 05:45 AM   #12
Brings The Mosh
Rollins's Avatar
I dont think it really washes very well, the soap doesnt seem to do a good job of taken off dirt or mud no matter how hard you scrub at it. Ya it dries, but I dont tihnk the finish product looks as good as a wash with Mothers or Maguiers <- or however its spelled
Old 08-06-2004, 02:56 AM   #13
white_xtreme's Avatar
i usaully wash my truck as i would normaly do with plain ol' soap and water then i will go over it with the MR. clean auto dry. the time it tackes me to do the mr clean is about the same as drying by hand with less hassel.
Old 08-08-2004, 02:38 PM   #14
She loves when I go low
jlAudioBooms's Avatar
Location: Ohio..Johnstown, gahanna, new albany, columbus
i wash my boss's Escalade and SLR 55 every friday and i tried using the mr clean soap and it left a film over the car so i just put my old soap in the mr clean and use it.
Old 08-08-2004, 11:36 PM   #15
Shitbag Sailor
LudacriS10's Avatar
Another tip is if there are any spots use those Auto Wipes, I think they are made by armor all, they come in a green box. They are basically wet naps and you use them and they leave barelly any moisture so they dry instantly and that cleans up the little here and there spots.
Old 08-21-2004, 08:51 PM   #16
XtremeTy
I didn't like it either, did my wife's GTP with it and it left spots. Figured I would test it on her car before I tried it on my Typhoon or my Extreme. Followed the directions both times and it wasn't worth the money. I'll just go back to using Mothers products.
Old 08-21-2004, 08:58 PM   #17
It worked for Superman
Grinch78's Avatar
It left a film on it? Sounds to me like the filter on it needed to be replaced. That is the only time I have seen a kind of film on my truck but when looking at it, it was obvious that it was from the water and not the soap. You could see all the mineral lines from it. That only happened because I used the filter for like the 6th time and the water around here is pretty hard. Anybody that doesn't get good results from this system is doing it wrong. And like it was said above, the polymer soap is part of the sytem. If you don't use it you won't get as good as results.
Old 08-21-2004, 09:14 PM   #18
PaintRush's Avatar
Exactly, the soap is the real key part of the system. Anyone notice how it is a little thinner than most carwash soaps? That's the "jetdry" in it.
Old 08-21-2004, 09:23 PM   #19
Grinch78's Avatar
Yeah, if you was one half of your hood with the autodry soap and then the other half with another car wash soap and then rinse it off. You can see how the water sheets on the autodry side.
Old 08-21-2004, 11:13 PM   #20
SVT Cobra Moderator
Offthehook's Avatar
my filter doesent work
Old 08-21-2004, 11:20 PM   #21
Grinch78's Avatar
What do you mean it doesn't work?
Old 08-23-2004, 11:56 AM   #22
GM junkie
Hoss's Avatar
I bought one and I like it. My house runs off of well water, and our water here is very hard. If I don't dry my truck after washing it it will have large gray spots all over it that you can practically scrape off with your fingernail. Drying it doesn't really get it all off either, it will still have gray streaks all over it but it's the best I can do. But using the Mr. Clean for the first time was the first time I could actually get the truck "clean". No spots whatsoever.
Page generated in 0.60611 seconds with 31 queries
[Output: 112.63 Kb. compressed to 103.88 Kb. by saving 8.76 Kb. (7.78%)]
