yellowing
Old 04-15-2004, 01:50 AM   #1
Mystik's Avatar
yellowing
what causes the yellowing of the lenses... can it be cleaned?
Old 04-15-2004, 10:39 AM   #2
Spark'n it Up
XtremelyLowRide's Avatar
Re: yellowing
Happens alot with older cars/trucks, you can never get it perfectly clear again but you can make it better. They have this stuff called never dull at discount auto parts and it says its used on metal stuff but works great on this....or youy can try waxing it REALLY REALLY good. It makes it look better but only temporary. It will go back unless u keep waxing/polish it.
Old 04-15-2004, 10:50 AM   #3
Polishing Guru
samandjen1's Avatar
Re: yellowing
Use this
http://www.eastwoodco.com/shopping/p...word=headlight
Or wet sand with 2000 grit sandpaper and the buff and polish.
Old 04-15-2004, 10:58 AM   #4
True Ambition
LowTech's Avatar
Re: yellowing
http://hotrodders.com/kb/body-exteri...ht_covers.html
Some plastic headlight covers yellow after a few years, including those on 87-93 Mustangs. To correct it, get some 400 grit sand paper, sand the covers, and use McGuire's #7 polishing compound with a buffer until you're smooth and seeing clearly.
Old 04-15-2004, 11:01 AM   #5
Polishing Guru
samandjen1's Avatar
Re: yellowing
IMO 400 grit is too ruff, you have deep scratches when done. At least start with a 600-800 grit
Old 04-16-2004, 02:41 PM   #6
SlammedDime's Avatar
Re: yellowing
And what if the yellowing is on the inside of the lense, like my clear tail lights?
Old 04-18-2004, 01:14 AM   #7
2 old 4 this
reams6100's Avatar
Re: yellowing
the yellowing on the tails is probably cause they used cheap plastic w/o UV stabilizers. if so, it's yellow all the way through
Old 04-19-2004, 08:58 AM   #8
True Ambition
LowTech's Avatar
Re: yellowing
I tried it this weekend on my thrid brake light with 600 grit....it did not work at all...oh well...you win some you lose some
Old 04-19-2004, 10:18 AM   #9
Spark'n it Up
Re: yellowing
Anyone know why? I was gonna do it to my girlfriends headlights.\ with 1000 grit. Whats the exact process?
Page generated in 0.68930 seconds with 31 queries
[Output: 66.34 Kb. compressed to 62.21 Kb. by saving 4.13 Kb. (6.22%)]
