Yellowed Tails
Old 06-12-2008, 09:17 PM   #1
Yellowed Tails
Just bought some of the "All Clear Tails". Got them today, and they're yellowed/greyed/stained past my liking. The reverse light area is fine though. The truck is pewter, and they don't look so great. Tried using chrome polish, and Scratch X. Did nothing. I've read rubbing compound, or toothpaste work, and I'll try them tomorrow.
Anyways, figured I'd throw em up here and see if anyone had some tips to clean them. I'm assuming it the outside of the lens (hopefully not the inside) that's colored. They look worse in person. Kind of tricky taking a pic with the reflection of the inside making it look better.
Old 06-12-2008, 09:24 PM   #2
SK wutt?!
lucky-13's Avatar
Re: Yellowed Tails
wet sand with 400-800-1000 grit sandpaper and buff out with plasic buffing compound, should do the trick
Old 06-12-2008, 09:43 PM   #3
bagged DD on 20's
Big_Bake's Avatar
Re: Yellowed Tails
^what he said. i would start around 1000 though, if it's taking too long to get them clean, then go down to a lower grit. i started at 1000 on my volvo headlights to clean them, then 2000, then buffed them with compound and they look a lot better, no more yellow.
Old 06-12-2008, 09:47 PM   #4
Re: Yellowed Tails
Thanks guys. Looks like wetsanding is what I'll explore tomorrow.
Is wetsanding something I should attempt? I've seen it done on TV with a spray bottle and some sandpaper, but with my luck...well...it wouldn't go well. lol
Old 06-12-2008, 09:50 PM   #5
Moosy's Avatar
Re: Yellowed Tails
atleast you dont have my luck, dont let me touch them, you'll get rear ended.
Old 06-12-2008, 10:27 PM   #6
Re: Yellowed Tails
Found some pics of what they should look like. I assume even though mine don't have the black trim, they'd be that clear.
Old 06-12-2008, 10:42 PM   #7
Certified Auto HVAC Tech
layinlow88's Avatar
Re: Yellowed Tails
wetsanding with such a fine grit of paper will be ok for you man...just be sure to not apply a ton of force....just some light pressure, water, and time....thats all you'll need
Old 06-12-2008, 10:47 PM   #8
goin broke but n style
S15vortecpwr's Avatar
Re: Yellowed Tails
when you wet sand make sure your paper and light stay wet, do no let wither get dry or it will make the light look worse.
I have heard of people using a drop or two of dishwash detergent just to help keep a smooth sanding pattern
Old 06-12-2008, 11:48 PM   #9
bagged DD on 20's
Big_Bake's Avatar
Re: Yellowed Tails
yep. we did that when i worked at the shop. filled a bucket with water and put some soap in it. helps suspend the grit and grime so when you rinse it comes off.
Old 06-13-2008, 10:41 AM   #10
Re: Yellowed Tails
Thanks again guys.
But, the more I look at the light, the more I wonder if it's actually yellowed, or that's just how they were made. I wish I could find someone else with them to confirm that, but the way the reverse stayed clear makes me wonder.
Old 06-13-2008, 11:08 AM   #11
Canyon Carver
Re: Yellowed Tails
I do believe they are yellowed. I've heard a lot of stories about how they turn yellow fairly quickly if exposed to a lot of sunlight. I put a little SPF 30 on mine whenever I leave the garage.
Old 06-13-2008, 07:04 PM   #12
Re: Yellowed Tails
After an hour or so of wetsanding, I think there's an ever so small difference for the good. But if in fact there was 2 styles (one with black trim and one w/o) it might be that the plastic of mine were manufactured like this, and all I've done was removed a layer of filth.
Old 06-13-2008, 09:01 PM   #13
bagged DD on 20's
Big_Bake's Avatar
Re: Yellowed Tails
ehh it was worth a shot. you could always hit it with some candy apple. mask off the reverse light, and they will look stock, but better. i think people use that duplicolor metalcast stuff. here's a link to a similar thread of what i'm talking about. http://www.s10forum.com/forum/f3/can...nd-gen-356104/
Old 06-13-2008, 09:52 PM   #14
Re: Yellowed Tails
I might look into getting them tinted pewter, so very similar to that. I'd like to get rid of all color but pewter/gray/white, so tinting them with pewter would hide them well.
Old 06-13-2008, 10:08 PM   #15
bagged DD on 20's
Big_Bake's Avatar
Re: Yellowed Tails
i'm sure they make some kind of pewter candy that you can use. if not maybe tinting clear. i know they do that with black tint to smoke tail lights.
Old 06-15-2008, 12:11 AM   #16
BTE
I have no idea
BTE's Avatar
Re: Yellowed Tails
The way it was explained to me is, that the yellow comes from the when the plastic is manufactured with too little of whatever protects it from UV light. So sanding won't do anything because it's yellow all the way through.
Old 06-27-2008, 07:09 PM   #17
327
High in the sky
327's Avatar
Re: Yellowed Tails
Man who makes thos clear tails?
Old 06-27-2008, 08:32 PM   #18
4x4 v6 blazer
neo71665's Avatar
Re: Yellowed Tails
Nobody anymore
Old 05-26-2009, 10:15 AM   #19
Fannatick's Avatar
Re: Yellowed Tails
Where do you buy 1000+ sand paper? I looking in Home Depot and they only went up to 800 grit.
Old 05-26-2009, 10:20 AM   #20
Re: Yellowed Tails
Vato zone
murrys
Old 05-26-2009, 10:20 AM   #21
Re: Yellowed Tails
ace hardware
Old 05-26-2009, 07:43 PM   #22
UN-BANNED B!TCHES!!!!!
NotaDime's Avatar
Re: Yellowed Tails
are you serious or just kidding??
Old 05-26-2009, 08:00 PM   #23
94 2.2, feel the power?
deathphoenix99's Avatar
Re: Yellowed Tails
I'm pretty sure that was sarcasm.
Old 05-26-2009, 09:33 PM   #24
NotaDime's Avatar
Re: Yellowed Tails
he might not have been kidding... it does block UV rays which is what yellows them....
Old 05-28-2009, 08:42 PM   #25
Boobies
leprechaun1874's Avatar
Re: Yellowed Tails
either way I got a good laugh
Page generated in 0.63575 seconds with 31 queries
[Output: 120.62 Kb. compressed to 110.89 Kb. by saving 9.73 Kb. (8.07%)]
