Whats the best product for cleaning windows with smoke buildup?
Old 07-31-2006, 11:49 PM   #1
blazinb2000
b_evans06's Avatar
The previous owner of my blazer was a smoker. So all of the windows are covered in a smoke like film that I cannot get off with window cleaner it just smears. Is there a stronger cleaner that you have used that will remove the film?
Old 07-31-2006, 11:51 PM   #2
NVR2LO
masssdime420's Avatar
Re: Whats the best product for cleaning windows with smoke buildup?
soak the window wit windex, scrub wit steal wool and clen wit paper towels. reapeat if neccasserry (sp)??
Old 08-01-2006, 01:35 AM   #3
<3 redheads
556mm's Avatar
yup invisible glass.
Old 08-01-2006, 01:35 PM   #4
Fronkensteen
The Griff's Avatar
if there not tinted spray it with foaming glass cleaner and then use a razor blade and it will come rigth off
Old 08-01-2006, 01:51 PM   #5
bangin Woofenhogens
formula 420 might work. Found at your local headshop
Old 08-01-2006, 01:52 PM   #6
Mcfly Minis inc
Mcfly Minis's Avatar
windex and steel wool for the win!
Old 08-01-2006, 05:20 PM   #7
crap
bg's's Avatar
White vinegar is a good cleaner too. Then Invisible Glass after using the vin. It'll smell good and be clean.
Old 08-01-2006, 08:15 PM   #8
ZR2 member
Scott01's Avatar
I smoke and I use this stuff with great results.
Old 08-02-2006, 01:03 AM   #9
blazinb2000
b_evans06's Avatar
I dont know it if makes a difference but the windows have factory tint on them in my blazer. Ill give the steel wool idea a try. Thanks for all the suggestions.
Old 08-02-2006, 01:06 AM   #10
2kdime's Avatar
i wouldnt even attempt it with the tint. it could scratch it.
i smoke too and ive been looking for something to help with the windows. ill try anything except steel woll
Old 08-02-2006, 11:07 AM   #11
XtremeChik20's Avatar
ArmorAll Auto Glass Cleaner It's awesome, my dad smoked, and when I would clean out his truck, windex smeared it, like yours.... I used this stuff, and it came off.... Use it once, let it dry, and repeat if necessary...... I found it at Wal-Mart for like 4 bucks....
Old 08-02-2006, 12:47 PM   #12
blazinb2000
b_evans06's Avatar
Thanks for all the suggestions and all the products. I dont think im going to use the steel wool on the windows Ill go buy a can of armorall auto glass cleaner like xtremechik suggested. Ill let you know how it works.
Old 08-03-2006, 08:37 PM   #13
Driveway Dreams Prez
sr98219's Avatar
Try using a vinegar and water mix and instead of towels, use newspaper. Neither of these will streak your windows and it comes off very easily. I'm a smoker myself and have been using this combo for years.
Driveway Dreams Prez.
Old 08-03-2006, 08:43 PM   #14
Hen oida hoti ouden oida
LoWeReDX10SiVeLy's Avatar
Stoner Invisible Glass > *
Old 08-06-2006, 01:05 AM   #15
I AM CANADIAN
tt85_GM's Avatar
The factory tint is not a film, its actual tinted glass, treat it like its any other clear automotive glass.
Old 08-13-2006, 04:47 PM   #16
Private User*
metalgear636's Avatar
I use the stoners invisible glass and its works great. I only clean my windows maybe every 2 months and it takes the smoke right off.
Old 08-13-2006, 09:17 PM   #17
NVR2LO
steel woolk will not damage windows with factory smoked glass. only windows with window film on them
Page generated in 1.40670 seconds with 31 queries
[Output: 93.85 Kb. compressed to 86.88 Kb. by saving 6.98 Kb. (7.43%)]
