wet sanding
im gunna be wet sanding my truck when i paint it what kind if compound should i use to buff it with?
Re: wet sanding
Remember with the wet sanding it comes off easy but goes back on hard. Some people start with 1500, I prefer to go slower and use 2000. Soak the paper for at least 15 min before hand, and tape off the edges. Good luck with it. Matthew |
cokehead
Location: Libertytown, MD- near Frederick User is: OffLine |
Re: wet sanding
tons of work, but WAY worth it. took it to the next level for sure. i also used 3m stuff.
drunk and bored
Re: wet sanding
read my sticky on restoring faded paint and there are pics of the compound,polish and pads that i would recommend....i made sure the product numbers were visible in the pics to avoid confusion.
the starting sandpaper grit depends on how smooth your finish is to start with and the final finish you want....the finer grits will just ride over the orange peel and smooth it a little but...the coarser grits will cut the peel down more you need to know how much clear is sprayed on to know how much you can safely remove...and no i can't answer that question unless i sprayed it or watched you spray it personally |
UN-BANNED B!TCHES!!!!!
Re: wet sanding
3M is so.... 20 years ago.
try this. http://www.optimumcarcare.com/optimumpolish.html heres a pic of a customer of mines cars that i buffed on for about 6 hours for major scratches.... i also have before and afters of wetsand jobs if youd like to see some more. ![]() Last edited by NotaDime : 04-22-2008 at 01:53 AM. |
R/C Guru
Re: wet sanding
Re: wet sanding
The link leads to a swirl remover/glaze compound and a cleaner wax, whats so special about them? You can't possibly be implying that those two compounds will do everything you need to do and are better than 3M's whole product line? |
Re: wet sanding
IMO, i dont like 3M compared to that optimum.
i have been professionally detailing cars for 16 years now, and i started off using 3M, but there is MUCH more out there that is better. i now own my own detailing business and still do detailing for a living. how is it better than 3M? well, it doesnt sling, it doesnt cake up and best of all a little goes a LONG way. you can buff a spot for a few minutes , put down the buffer, walk away then come back and buff some more and wont need more product. i have been using it now for about 2 years and wouldnt use anything else. i do a few 100,ooo plus cars and get superior results with there line of products. |
Re: wet sanding
Working on the detailing end I would venture a guess that most of your work can easily be done with those two products, the swirl remover/glaze, and the cleaner wax, but for someone in the refinishing business and such, I expect you'd want a little broader selection which 3M offers. Not that you'd use it all the time, but it's there for when you need it. I'm not saying they are the best hands down no contest, but locally pretty much everyone I know of in the refinishing and body working business use 3M, it's what I was exposed to growing up, and it's what I use now, and I've never been unhappy with it. To each their own though, I know some people who swear by turtle wax. ![]() |
drunk and bored
Re: wet sanding
and don't even try to tell me that shit doesn't sling.....i can sling any non slinging compound or polish you go ahead and use whatever you want but i PAINT cars....we are talking about wet sanding and buffing a fresh paint job....not DETAILING factory finishes...there's a big difference i have used lots of products over the years and nothing can touch 3m(and i HATE 3m but i use the best so i don't have much choice) |
Re: wet sanding
i got about 45 hours of sanding and buffing on it. to buff it, only optimum products were used. |
Re: wet sanding
here, ill make it easier for ya'll non searching ass's http://chevyrumble.com/ME2/Audiences...17F5A2AB5401FA |
Re: wet sanding
farecla total one step buffing compound and pad works pretty damn good... and its water-based. i would still reccomend some swirl remover for dark colors and a good hand glase. its been a while since i used perfect-it, but i do remember it working fairly well.
drunk and bored
Re: wet sanding
45 hours to sand and buff a camaro....i don't miss that shit at all
Re: wet sanding
