bagged 89 s10
water spots on truck and windows/
how do i take them off.
Landmine Carburetor
Not to sound too stupid, but washing it normally takes it off. Probably have to scrub though, like use the brush at the car wash, or use a rag or somthing. Then make sure to dry it with a chamoise or a towel.
bagged 89 s10
i tired that on the body and windows but it wont come off. just washed my truck today to.
Hard water spots will come off with a Mothers brand clay bar kit, windows and paint, I used one on my 96, it also makes the paint smooth as glass after a coat of wax.
I drive the short truck
for the windows i use a trick my grandpa taught me it sounds stupid as hell but take glass cleaner (i.e. windex) and some newspaper spary the glass and wipe with the newspaper i was skeptixal but then he did it and it woks like a charm
as for the body clay bar all the way |
Ticket Magnet
Cirium oxide from a glass shop or Bon Ami will take off the water spots and polish the glass. Do not use it on the paint...
bon ami does work... i have used it on a few vehicles at the dealership i work for..... |
bagged 89 s10
Re: water spots on truck and windows/
i got the water spots off the paint and i used rubbing compound with a buffer that my dad had,but i still didn't do my windows yet and i have to do it before the next cruise next month.
ninety_nine_s_10
Yeah, be sure to wash the inside and outside of the windows when you wash your truck.
I use newspapers on the inside. Usually, just a damp cloth works... not too wet, but wet enough to remove the spots. Newspapers do the trick on the inside though. |
NOT AN ADMIN!!
if u have those really bad water spots on your glass, get steel wool (not scotch brite) just the plain steel wool and oven cleaner and put oven cleaner on there and scrub with the steel wool, it works wonders.
The f@$k you want foo?
I've seen many S10's w/ this prob. Most the time either Bon Ami or a clay bar will cure the spots. I've also had another experience w/ my s10. The "spots" appeared to be on the exterior but were actually between the glass. What I mean is that the glue on the safety layer had actually caused this "water spot" appearance. I've seen this on lots of cars but haven't heard or seen this on an s10, until now. Final cure, A big f'n rock! $50 deductable. Done deal!
Hard water spots are a common problem caused by the chemicals used in tap water. The most effective way I've found to avoid spotting is to dry your vechical immediatly after washing.
Another good reason to dry your vehical afterwards is that if you wash your vehical during the day the water droplets left on your vehical act as a magnifier causing pits in your paint which becomes really noticable on darker colors.
Landmine Carburetor
Man...I get well water sprayed on my truck all the time, and just full of nice spotting minerals, and if you just spray it it won't come off. But if you use the brush at the car wash it comes right off. I don't think i'd want to drink the water you guys get on your trucks, is it even clear? haha...
Fatty~BooM~Daddy
without the 20's...
If you do scratch it using something else, use sirium oxide powder and it'll remove minor scratches. |
