water mark help!
Old 03-05-2004, 04:18 PM   #1
Do what now?
supr2nr's Avatar
water mark help!
Okay I have a question and I am not finding a lot of help on this from the search function. Since I have bought my truck I have had water marks etched into the windows . I have tried almost everything that I seen on the shelves at local auto parts stores to try and get rid of the water marks but nothing has worked. Does anyone know of a way to get these out? Is there anything on the market that I can buy that will get rid of them? Someone out there must know of a way to get rid of these things.
Please help me!
Old 03-05-2004, 05:54 PM   #2
Do what now?
supr2nr's Avatar
Re: water mark help!
bump!
Old 03-05-2004, 06:56 PM   #3
I'm probably drunk.
BLAZ1N's Avatar
ive heard that clay bars will work
ive never had this problem so im not sure
but you can buy them at a auto parts store
it is a bar of clay that usually comes with a special kind of soap
they are meant to be used for paint, but ive heard they work on windows too
they are like 15 bucks, maybe a little less
if that doesnt work call a local bodyshop
i know there is a chemical that supposedly takes it off
but im not sure what its called
hope this helps
dave
Old 03-05-2004, 07:15 PM   #4
Do what now?
supr2nr's Avatar
thanks for the reply!
I will check out a clay bar.
Old 03-07-2004, 07:03 AM   #5
The f@$k you want foo?
jakedubb's Avatar
I have the same prob. turns out the water marks are actually between the layers of glass. Looks like water marks on exterior but is actually the resin/glue inside the window. Best cure is a big rock and a $50 deductable
Old 03-08-2004, 06:10 PM   #6
Do what now?
supr2nr's Avatar
LOL!!! I'm beginning to think thats what my resolution will be too!
Old 03-13-2004, 02:05 AM   #7
former title junky mod
Futuresweets10's Avatar
its on the ouside, not between. You cant feel the spots when they are on the ouside. In my two years working at a detail shop I tried claybar on waterspotted windows many times and it never worked, We had a chemical company that made stuff just for us and we had a spot removeing chemical that worked great. I can still get it but its about 50 bucks a gallon and a gallon is the smallest size available.
Old 03-13-2004, 06:46 PM   #8
Psycho
Hazardous's Avatar
get some brasso brass polish and buff the window
Old 03-13-2004, 08:59 PM   #9
rcharris's Avatar
There is a cleaner that they make for smooth stopetops (with the glass burners). It takes a lot of elbow grease, but works excellent. Go to any appliance retailer and they should have it or be able to get it for you.
Old 03-16-2004, 03:31 AM   #10
sloooow downnn!
low_eskimo's Avatar
back in the day we used to use glass cleaner and 0000 steel wool.
Old 03-16-2004, 03:45 AM   #11
AntiRice's Avatar
maybe try rubbing compound and buff that bish
Old 04-05-2004, 10:41 PM   #12
There was another thread on this a while back and after reading it I tried everything ppl posted in the thread and nothing worked. The claybar didnt work, CLR and some other limeaway stuff didnt work either then I tried rubbing compounds and got no where with that crap either. Finally I went to a place here in my town that does glass work and bought this stuff called "A-maz". The guy who sold it to me said if this wont take the spots off then they wont come off. I used it on my windshield and its amazing. You can feel how smooth the glass is again and I dont see any of the hard water spots that were there. On the side windows I had to apply it a couple of times but it worked on those windows too. The stuff is called A-maz and it says on the can that its manufactured for Sommer & Maca, Cicero, IL ph:800-323-9200.......and I think it cost like 8 bucks.
But by some claybar too......makes your paint feel better than silk.
Old 04-07-2004, 10:15 AM   #13
Ticket Magnet
Rhotpursuit's Avatar
Go to a glass shop and get some cerium oxide. CR Lawerence makes it. (probaly others also) It's a pinkish powder. Take a sponge or wax applicator and get it wet then wring it out as best you can and dip it in the C/O. Use circular motion until all the spots are gone. DO NOT USE A BUFFER!! Rinse well. If the water does not sheet off re-apply. It may take several tries but it does work. it will remove light to medium scratches as well. I use it about twice a year to get all the crap off that accumulates. Between applications you can use Bon-Ami to polish your glass. I used to do service work on the side for a major window mfgr and the C/O cured a lot of defects. Hope this helps....
Rick
Page generated in 0.66282 seconds with 31 queries
[Output: 80.51 Kb. compressed to 74.94 Kb. by saving 5.57 Kb. (6.92%)]
