Water leak into Interior
Could'nt find a thread on this. I have a water leak into the inside of my truck. Passenger side floor board and in the rear has water puddling....
I re-caulked the rear vent in between the cab and bed... heater core i used sealant... still seems to have some water comming in some how. Any common problem that i dont know about, before i take all the interior out and find it the hard way? thanks for any help... |
Re: Water leak into Interior
Is it an extended cab? My rear side windows leaked BAD on mine. I just took them out, cleaned them up, and put some new weather stripping glue on them to seal them up. Also check around your rear window.
Useless posting member
There's a drain plug under your wiper cowl somwhere. If it gets plugged up, it can send water into the cab.
haha ya guess I forgot to add that. That's a pretty common one since leaves and all kinds of just can easily get down in there and plug the drain up very easily. |
it seems to be puddling in the back more than the front. other than the window is there any other part that can be leaking. its not comming from under the truck, cuz i had it park over night and before it was dry and now (morning) its wet.. i lifted the back part of the carpet and doesnt seem the be comming from were the raised back part is (under the window).. i guess i gotta wait for some good weather and pull everything out and check that way..... errg.
Take a bottle of water and pour it around your back side windows. That's how I found my leak back there. Once it comes in around that window it usually goes back behind the plastic paneling so It's kinda hard to find unless there's water coming in while you're looking.
I had this happen to me..I had a drunk buddy of mine in the back and I guess he leaned against the back glass to much and popped the seal. Took a lil while to figure it out. I finally noticed one day when i closed my door and my back glass bowed out. I took my time and used some clear RTV silicone sealer from autozone. No more problems ,would never know it was there.
hmm, ill check the window for sure, thanks for the help..
Urban Hick
What year is your truck??? If it's a 2nd gen check around the third brake light....sometimes those allow water to leak into the back.
Also confirm that it's not leaking in the front, if it's leaking in the front then you've got a huge list of possible leak areas to check. I had a leak in the front driver side that took me close to 6 months to find.....Water leaks suck! Last edited by Firm : 02-03-2009 at 10:40 PM. |
yea I was going to say the third brake light if you have 2nd gen.
Its a 99, the 3rd brake light is shaved. I pulled the interior and wet the outside and looked like the water was comming in from the back window at the top corner. caulked it. It seemed as though water was in the front passenger side, im thinking that it was traveling from back to front,(i hope) other wise i got a leak in the front as well. What are comman places in the front to leak?
Urban Hick
Do a good search of the forum for a complete list of front leak areas....but heres some for the passenger side that i can remember:
-grommet where anntenna comes through the firewall -A/C drain is plugged and backin up into cab -wiper cowl drains(on either end of the inner 'trough' are plugged(the passenger side one is difficult to access -seam seal in the wiper cowl is dried out/broken -door seals arn't fitting tight along the roof and water is dripping in Theres more, I just can't think of them all right now.....These truck tend to have issues with water leaks - pretty crappy if you ask me. |
Have you seen my glovebox
here's one.. i got a drip/inside run that looks like its coming from the center on the windshield right at the top.. any ideas?
V8 with bags
ive seen first gens leak at that same spot. The little rubber trim around the glass got old, shrunk some and let water get to the glass/metal where it was suppose to be fully sealed, and let in alot of water.
Urban Hick
yeah...that'd be my guess too....you should prolly take it to a windsheild shop and have them look at it. But if you wanna be ghetto maybe pull the rubber out of there(very carefully) and then reseal it with some rtv...then reinstall the rubber over the wet rtv.
A good way to check for a leaking window seal is to use some soapy water on the outside and a compressed air gun on the inside. You will see bubbles as soon as you hit the spot that's leaking with the air nozzle. Easy as pie.
i have a 2001 extreme blazer and im getting water on the passanger side also someone told me that it could be where the antenna wire goes threw the fire wall and someone also told me to reseal the box around the heater fan but i dont feel like taking stuff apart if its not going to work ....anyone know if this stuff is true?
Yes, it can leak in those areas. |
my 83 has a cargo light on it,,,ill have 2 see if it is leaking
user
i have the a gnarly leak in my truck....passenger side had an inch of water when i pulled up the carpet.....
the carpet is still soaked after drying out for a day(i put a heater in the truck overnight too) my carpet smells moldy/gross/nasty....can it be cleaned? do i have to replace it? |
Urban Hick
user
its a 2000....i have a good idea where its leaking from....not concerned about that part of the equation.....
just curious as to the best way to clean the carpet and pad....its soaked thru...will the mold smell ever go away? or will i have problems down the road with more mold and nastiness? i was thinkin id have to pull the carpet and clean with diluted bleach and then rinse and repeat and dry? do i need any special tools to pull the seats and stuff? |
#24 |
i just wanted to say i just got a new windshiled and noticed a few days ago my driver side was really wet and it had alot of water under the floormat, he did a good job from what i can tell ( seems sealed good) maybe its the drain plug in the cowl? any pointers to where its at exactly? thanks
#25 |
Urban Hick
As usual there is a ton of spots it can be coming in from, best thing to do is to search some of the threads around here. Heres a GM service bulletin kickin around in some of those threads that can be quite helpful.....I had a leak coming in from the driver side upper corner(behind the dash) and I've posted a thread about how I finally found and fixed it.
#26 |
Good lord I hate water leaks! The drivers foot well in my 93 gets soaked every time it rains hard. I've been chasing this freak'n leak for months with no luck. Oh well, guess I'll just keep chasing!
#27 |
still not low enough...
Two weeks after I bought my truck, I was driving in a bad storm. At the top of the passenger side pillar, water suddenly shot out in a stream! Like a bad nose bleed! Holy crap! Turns out the seal around the windshield was bad. Dealership left it in the sprinklers all day to make sure they fixed it right. Crazy story I thought I'd share.
#28 |
B JELUS
My Xtreme had a leak. We figured out it was the little "filler" strip that runs along the roof above the ext cab on the passenger side. Just filled it with some clear stuff. You can't even see it.
I would rip the carpet out back where your seeing the puddle and then get inside and have a buddy spray down the outside. You should be able to see where the water is comming from and then trace it to the source. |
#29 |
Urban Hick
Heres the thread where I posted how I found mine....Corona, it sounds like your is probably in the same spot. Took me months to find this shit.
http://www.s10forum.com/forum/f137/m...k-long-378915/ |
#30 |
#31 |
There are also drains in the door at the bottom. Get on your back and look up at them. If they get plugged water will pool inside your door and leak into the cab.
#32 |
what do you think i should try to do first? i realy hate the feeling of taken this shit apart its still a virgin..lol
#33 |
drag that shit
it could be one of the heatercore hoses. did you check you radiator lately to see if it is low. if the radiator is low the start at the heater core
#34 |
wat do i have to do to get to the drain plugs in the cowl on the passenger side? i sealed the antenna gromet it is still getting water inside .
#35 |
Heavy Metal Junkie
where is the A/C drain located? im havng water get in from some were and me passenger floor keeps getting wet but iu havnt used my ac in a while so does that mean its not the ac drain?
