Water in tail light
Old 07-26-2007, 04:58 PM   #1
Water in tail light
Howdy all,
My driver-side tail light has collected moisture in it. So I took the tail light housing off and let it dry in the sun, the problem is it left water spots inside of the lens.
Does anyone know how to clean or remove the water spots?
Thanks for any help
Old 07-26-2007, 05:18 PM   #2
ASASN8
bladehines's Avatar
Re: Water in tail light
only way is to remove the lens by heating it in the oven at REAL low temp then pry the lens loose, and clean it, then glue it back on!
Old 07-27-2007, 01:13 AM   #3
Deadmonton Survivor
saladonthebeach's Avatar
Yeah, if the seal is deficient.. you should do the method noted above or get a replacement.
I usually wash out my headlamp buckets and tail lights with a spray bottle of household 'no streak' window cleaner, I try to avoid using water at all costs. I've had pretty good luck doing it like that.
Old 07-27-2007, 01:52 PM   #4
bellcranks no more
greencactus3's Avatar
you can try to slosh distilled water or filtered water or w/e it is that doesnt waterspot. then drill holes in the bottom so it wont happen again
Old 07-27-2007, 07:05 PM   #5
Molon Labe
BudRacing's Avatar
I'm pretty sure drilling holes in the bottom is gonna let moisture in there again... completely defeating the purpose of resealing them.
Old 07-28-2007, 03:14 PM   #6
I'll give those suggestions a shot this weekend. I'm not so sure about the drilling a hole in them part, as I'm pretty sure the current (but unused) screw hole that was in the tail lights is where the moisture was getting in at.
Are there directions here somewhere on how to remove the lens from the tail lights using the oven? I searched but couldn't find anything.
Thanks for the help
Old 07-28-2007, 05:07 PM   #7
bellcranks no more
if you drill in the correct place so it drains, water should leave faster than it gets in
Old 07-28-2007, 11:45 PM   #8
Molon Labe
BudRacing's Avatar
There's no stopping humidity if its unsealed.
Page generated in 0.60548 seconds with 31 queries
[Output: 62.77 Kb. compressed to 59.02 Kb. by saving 3.75 Kb. (5.97%)]
