Useless
Water deflectors
Ok so one of my deflectors came off on the outside of my window and the glue part is still on there.... does anyone know ANY tricks to getting this off so i can get a new deflector on there
Re: Water deflectors
I used a pressure washer, but it still took a while that stuff is no joke.
i used a piece of dental floss on the heavy stuff then rubbing alcohol on what was left
4x4 v6 blazer
I rolled the crap off with my thumb and then used paint thinner on a rag to get the rest off.
Urban Hick
Either use your finger or some fishing line/dental floss to get the heavy stuff off, and then a small amount of paint thinner on a clean rag to get the rest.
I wouln't use a pressure washer, thats just looking for trouble. |
3m adhesive remover works wonders also good for lots of things and will not harm your paint
where's my chippy?
Lol, I don't run my washer balls out.
Minitruckin' 4 life!!!
Acrylic solvent aka ACRYSOL is good for that stuff... or you could try the carb cleaner from BG.....
http://www.bgprod.com/products/fuelair2.html |
forum idiot
i yelled at mine and it fell off...
na i used a 3m glue remover ...worked great |
The Blue Pwns Joo!
Either the 3m stuff as mentioned before or the GooGone Gel shit works pretty well if you let it soak.
I SHIT BRICKS
i would say the 3m shit it works wonders
Anyway, they also sell a rubber wheel that takes that stuff off as well. This just an exapmple of what I'm talking about, but they make others that you can just simply attach to an drill, or grinder... ![]() |
Useless
thanks you guys i couldnt find 3m so i used goo gone instead and it worked great
Drive it like ya stole it
I had similar issues when I removed my cap and it had that gasket material stuck to my bed rails. I had to take it off with a fine fishing line then come back and get what was left and the glue residue off with acetone on a rag. Looks mint now!
