Blazer User
using a degreaser on wheels?
can it be used on the center caps on my stock swirls?
it has a lot of grease/dirt/mud/gunk.... if not what can be used? |
Short Bus Anonymous
Re: using a degreaser on wheels?
Yes it should not hurt the plastic caps....
I SHIT BRICKS
it will not hurt the caps we have done it before and it looks really really good
Lifts are for 4wds!
Yup, shouldn't hurt as long as you don't let it sit forever and a day.
I've done it before and works well. |
Blazer User
thanks guys!
Blazer User
what about engine brite or black magic engine shine?
dont worry im only using engine-type degreaser ![]() |
Lucky
i used alloy wheel cleaner on a set. just spray on sit for 2o sec and wash.
Minitruckin' 4 life!!!
Sometimes, if you're not sure, it's best to get the wheel wet before applying the solution/degreaser to the wheel, and possibly work it in by hand, and then rinse the wheel AS SOON as you're done cleaning it. Also make sure the surface of the wheel is cool, and only do one wheel at a time.... you don't want a chemical sitting on your wheels, and working it's way into the clear coat, while you're still cleaning the first wheel.
Pirate Astrenaut
![]() This is what I use, wheels look brand new afterwords. |
I get my degreasers from the dollar store.... they work GREAT! Also, take the center caps off when you clean them, and you'll be able to get all the cracks, and crevices better.
Uncommon Engineering
use it all the time on my painted wheels
