tail light has condesation in it... how to clean out?
Old 04-06-2004, 07:31 PM   #1
No tailgate's here
i4i4i4's Avatar
One of my taillights (aftermarket but the last owner put them on so im not sure what brand/model they are) has condensation in it, what might be causing this? and how can i fix it? the other one is just fine
Old 04-06-2004, 07:37 PM   #2
Got Beer?
2LW2TW's Avatar
Re: tail light has condesation in it... how to clean out?
Usually if you drill a small hole in it on the inside of it the condensation will have a place to escape. Thats what I did to the clear corners on my other car and it went away in a couple days of the sun beating on it.
Old 04-06-2004, 07:38 PM   #3
The Heezy To The Skeezy
SKiZZ's Avatar
A hole causes it. The heat from the light bulb and the mixture of hot cold and moisture cause the condensation, unless you can take it apart, clean it, and reseal it, look for another pair.
Old 04-06-2004, 07:43 PM   #4
www.myspace.com/MINTSICK
jmwxtreme43's Avatar
exactly, i had to get new clears, mine fogged, turned color, condensation, tried taking it apart, wasn't happening, let them dry out in the sun for a day, within 2 days they were fogged again, got a new set, have looked great since
Old 04-06-2004, 08:06 PM   #5
Got Beer?
2LW2TW's Avatar
Yes obviously a tiny hole in the sealant causes it and lets water seep into the light but its not big enough for the ventilation of air to quickly evaporate the water. Either way, sealing it is the best thing to do obviously, but letting air in to get rid of the water that is there can help as well as long as you drill it in a spot where water can not be let in anytime in the future. It worked for my lights, thats all I can say.
Old 04-06-2004, 10:10 PM   #6
No tailgate's here
i4i4i4's Avatar
thnx ill try that stuff out
Old 04-06-2004, 10:13 PM   #7
needin 20's member
98dimebag's Avatar
On the ones I used to have there were 2 rubber plugs on the inside of each taillight. One on the upper rear and one on the lower rear. Pulled em both off and parked it out in the sun and the condensation dissappeared.
Old 04-06-2004, 10:14 PM   #8
has committed suicide!
Got-20z's Avatar
what i've done in the past is use a blow gun on my air compressor or a hair dryer and dry it out well then put some Goop or silicone around the edges...
Old 04-07-2004, 07:59 PM   #9
I <3 (.)(.)'s
cbauer210's Avatar
Drill a tiny hole in the back of the light. The condensation will dry up. Seal up the hole with epoxy or silicon. Seal up all the edges with clear silicon to make it airtight. This is what I did and hasnt had that problem since. It is a quick and cheap alternative to buying new lights. If it fogs up after you do this and you cant find where the air leak is, then just drill the hole some where that wont allow water to enter, and dont seal it up. At least then it will have someplace to vent.
Old 04-07-2004, 08:29 PM   #10
Got Beer?
2LW2TW's Avatar
Glad to see that someone else thinks like I do...Thanks for the support.
Page generated in 0.62943 seconds with 31 queries
[Output: 71.93 Kb. compressed to 67.44 Kb. by saving 4.49 Kb. (6.24%)]
