swirly wirlys
Old 11-06-2005, 05:31 PM   #1
dun4sho
david owens's Avatar
swirly wirlys
in a certain angle in the sun i can see light swirls whats the best way to get rid of them? i have a slow speed 9 inch walmart buffer but what else do i need ? the paint looks awesome in the shade
Old 11-07-2005, 09:25 PM   #2
Rustbucket Club
LikeaRock's Avatar
Re: swirly wirlys
Those aren't swirls, it's called spider webbing
The only way to remove them is to use an abrasive polish with a high speed or a D/A polisher, if you don't have access with one or can't afford one right now, ask a detail shop if they can give you a discount if you help out.
If you can afford one, I highly reccomend buying a D/A polisher like the Porter Cable. It's virtually impossible to leave swirls or burn through the paint, and they're just as effective as a high speed, unless you're remong serious paint defects. After you use it once it pays for itself
Old 11-07-2005, 09:32 PM   #3
dillon_b12's Avatar
Re: swirly wirlys
Seems like Porter Cable has a monopoly on D/As...I only hear ppl recommend it. By the way, stupid question, what does D/A mean?
Old 11-08-2005, 03:11 AM   #4
Rustbucket Club
LikeaRock's Avatar
Re: swirly wirlys
D/A means Dual Action, just like a D/A pnuematic (sp) sander. And yes, they've more or less cornered the market on them. DeWalt and a couple others are out there, but they don't seem to be as effective or cost more
Old 11-08-2005, 04:18 PM   #5
Nate01Xtreme's Avatar
Re: swirly wirlys
A good wax will cover it up. Try Meguiars Gold Class. Damn good wax.
Old 11-08-2005, 06:00 PM   #6
Rustbucket Club
LikeaRock's Avatar
Re: swirly wirlys
Waxing won't do anything, even if you use a wax with fillers you can only remove them with a good polishing
Old 11-08-2005, 09:42 PM   #7
Re: swirly wirlys
That isnt true. Its possible to remove spiderwebbing by hand but it would be alot of work. Poorboys ssrs and scratch X will do the job. Like I said, your arm might feel like jello after words though.
Old 11-08-2005, 09:59 PM   #8
Rustbucket Club
LikeaRock's Avatar
Re: swirly wirlys
It'll work, but in order to truely remove them you need to get heat into the paint, that's where a high speed or something like the PC comes in. you aren't going to reach 1,500 RPM's by hand
Scratch-X works good for minor blemishes and spider webbing and such. It might take a few applications to get a good result, but it'll do the job. But like I said, in order to TRUELY remove them, you need a polisher
Old 11-08-2005, 10:56 PM   #9
Re: swirly wirlys
Heat has nothing to do with removing them. It might help in breaking down abrasive products but isnt neccesary. Like you mentioned above, you do need an abrasive product but it is in combination of product and working the it. If you dont work it enough the abrasives wont break down. Heat is just one of the things that happens because of the pressure and action of the machine. But I could be wrong but dont think so.
Old 11-08-2005, 10:58 PM   #10
dillon_b12's Avatar
Re: swirly wirlys
Heat does having something to do with it.
Old 11-08-2005, 11:09 PM   #11
Chyeah
StaticDime02's Avatar
Re: swirly wirlys
LikeaRock, any suggestions on a Porter Cable D/A that your talkin about? A link would be good too.
Old 11-08-2005, 11:11 PM   #12
dillon_b12's Avatar
Re: swirly wirlys
I believe the one everyone recommends is a Porter Cable 7424.
Old 11-08-2005, 11:18 PM   #13
Re: swirly wirlys
What makes you think. Like I said, Its just there from the machine rotating or orbiting. It might help but you dont need it. I understand pressure causes heat but its the working of the product that makes it breakdown and polish.
Old 11-08-2005, 11:18 PM   #14
Yee Haa!!!
imstur2's Avatar
Re: swirly wirlys
how much is that?
Old 11-08-2005, 11:21 PM   #15
dillon_b12's Avatar
Re: swirly wirlys
The heat breaks the clear down somewhat I believe and helps it flatten. If that makes sense...
Old 11-09-2005, 03:59 AM   #16
Rustbucket Club
LikeaRock's Avatar
Re: swirly wirlys
Exactly, you need heat to break down some of the abrasives in certain polishes. Doing sratch/swirl removal by hand can be successful, but it can't touch the rsults you can get with a high speed or a D/A
Static: Check out www.detailcity.com for anything you need to know about it, there's some tutorials as well as other information about the right pads/polishes to use. They also have a lot of links to sponsors over there that carry the PC and everything you need to go with it. I'd type the links in, but I'm kinda lazy right now
Old 11-09-2005, 12:04 PM   #17
Chyeah
Re: swirly wirlys
Thanks man, I was lookin at a few places last night, and I'll definately check that site out.
Old 11-09-2005, 10:20 PM   #18
ANGRY BABY!
Metlhed01's Avatar
Re: swirly wirlys
eh, i loved my Dynabrade D/A. never used a porter cable though.
Old 11-28-2005, 02:43 AM   #19
NVR2LO
masssdime420's Avatar
Re: swirly wirlys
all the truck needs is a really good buff. get yourself a dewalt buffer and some lite finish and some ip200 swirl remover. cut the whole truck with lite finish and a wool pad at a slow speed, likke 1400, then polish it with ip200 and a foam pad and finish with wax. the best wax u can buy is mothers in a red can, pure caranuba car wax
Old 11-28-2005, 03:06 AM   #20
Honest Abe's Fab Shoppe
BlackEsDime's Avatar
Re: swirly wirlys
the best way to do it, is to use a high speed buffer with a mild abbraisive rubbing compound and machine glaze... and if you don't know how to high speed buff, i wouldn't recomend doing it, you can burn the paint and rip off moldings pretty easy at 2000 RPM.
Page generated in 1.49426 seconds with 31 queries
[Output: 108.18 Kb. compressed to 100.14 Kb. by saving 8.04 Kb. (7.43%)]
