Suggestions for getting tires black again ?
Old 07-12-2005, 03:20 PM   #1
crap
bg's's Avatar
I really need to get the tires back to black again. They have this weird yellowish
tint to them and they look nasty. I don't want to send away for something, is
there a GOOD product I can buy at the local autoparts store that will help get this
nasty yellowish-smog type layering off the tire's sidewall ?
Any help is appreciated, thanks.
Old 07-13-2005, 03:09 AM   #2
Got keyless door handles?
XBLZR03's Avatar
Re: Suggestions for getting tires black again ?
Whestley's White Wash cleaner
Old 07-13-2005, 11:22 AM   #3
FULL THROTTLE
Licht's Avatar
Yup, Westleys Blech-White Cleaner and Brush, Works awesome.
Old 07-13-2005, 12:39 PM   #4
buellwinkle's Avatar
I use Eagle One's A2Z Tire and Wheel cleaner. Spritz it on good and scrub with a brush. The brown residue is the ozone in the tire that leaches out as you drive, the rest of the dirt is brake dust and street grime. Then apply a dressing like No Touch or Meg's Hot Shine.
Old 07-13-2005, 02:52 PM   #5
crap
bg's's Avatar
Thanks all for the tips !
Old 07-13-2005, 02:56 PM   #6
Rollin` Proud on 15's
Eight433's Avatar
comet or ajax will work too.
Old 07-21-2005, 01:10 AM   #7
Gots me a 4x4 too!
DropNDestroy's Avatar
comet works great! I used to use it all the time on my fullsize to really make the white lettering on the sidewalls stand out
Old 07-21-2005, 09:41 AM   #8
slowly, but surely.
sdime98's Avatar
i use bleche-wite
Old 07-21-2005, 08:43 PM   #9
Rustbucket Club
LikeaRock's Avatar
elitued 50/50 or even 75/25. Let it sit on the tires for about 2-3 minutes then scrub the living hell out of them, and if you have a pressure washer hit it with that, if not use the jet setting on a spray nozzle. They should be looking great, and after a couple coats of tire shine they'll look even better
Old 07-21-2005, 10:04 PM   #10
Plan Havin MF
Criticalbeatdown95s's Avatar
Sounds like a case of using armor all to me.....shit sucks in dirt like mad and eventually will make your tire crack.
Old 07-25-2005, 11:08 PM   #11
dillon_b12's Avatar
The brown shit is wax that the tire manufacturers place in the tires( I believe to help keep the rubber in good shape.) There was an article about it in Automotive Engineering a few issues back. BF Goodrich actually just came up with some new kind of wax that is black so it eliminates the browning. BUT Bleech-White is good stuff. My dad has always used Armor-All on the tires and I do as well, we've never cracked any tires and they always look great.
Old 07-26-2005, 05:48 AM   #12
square bodies ftw
cruisinlows10's Avatar
shout or any of that laundry pre-treater will work too
Old 07-26-2005, 05:33 PM   #13
crap
bg's's Avatar
Thanks again for all the tips. I've never used Armor All, but did use Son of a Gun...I have
also used that McGuires gel crap..Never again. I just want to get that nasty yelloish haze
off of them. I'll try all the products above and see what pans out best. bg
Old 08-01-2005, 06:48 PM   #14
96 S10 4.3L XCab
You can also use degreaser and scrub brush. Use Armor all or something like it afterward.
Old 08-01-2005, 11:47 PM   #15
crap
bg's's Avatar
Well tried the Westleys stuff. Worked real good on part of a tire. Problem is I got some on
the wheel which is alum. Messed it up a lil, but was able to polish it out using Flitz. I'm going
to make a round 15" cover that will snug up on the lip of the wheel so's to keep the
Westley's from getting on the alum. Once done I'll just pull the cover off and clean up what
little gets on mag.
Thanks again for the tips.
Old 08-10-2005, 03:26 AM   #16
Lifted without a clue
Svenson14's Avatar
"NO TOUCH"
you can get it at napa or most auto stores go try it
Old 08-10-2005, 03:39 AM   #17
Registered Asshole
Lowsonoma03's Avatar
i dont believe in thet "spray on, watch is clean itself" shit....theres too much grime and stuff on the road to watch a spray clean the tire. A lil elbow grease doesnt hurt..
Old 08-14-2005, 10:44 PM   #18
Blown Mod
Jess's Avatar
today, i found that i have a bad case of brown tire. i used a brass brush and DAWN. i had to scrub my ass off just to get a small, 6" section, of the tire clean. PITA. but i don't want to stain my wheels.
Old 08-14-2005, 10:49 PM   #19
#2 Post Whore
Bennelton's Avatar
Bleach-white is the shit. Just don't breathe too deep when your sprayin it
Old 08-21-2005, 11:43 PM   #20
Blown Mod
Jess's Avatar
i got my tires clean ! i used brake cleaner and a lot of rags. lots easier than the way i was doing it before.
Old 09-18-2005, 02:39 AM   #21
Svenson14's Avatar
i know i didnt like the thought of magical stuff. but a local auto shop recomended it, he sprayed some on my gross @$$ fenders and it turned them to brand new looking black within minutes it did the same for my tires
im serious it actually works......perfectly its like 5 bucks a can, its worth a try
Old 09-19-2005, 03:23 PM   #22
Lightbulb Re: Suggestions for getting tires black again ?
Simple Green.................That shit is amazing. I use it full strength on engine compartment and tires and about 4oz in 5gl to wash. But don't let it dry on the car!
Old 09-21-2005, 06:31 AM   #23
Quote: Originally Posted by Svenson14
"NO TOUCH"
Yes! NO TOUCH tire shine is the shit. The liquid (purple can) is easier to work with than the foam (white can) but it's all good. It's cool cause if you get a good coat of it on there it will last a while and the next time you go to clean your truck or detail it or whenever you tire shine it, you just wipe the old stuff off with a rag and the dirt goes with it. Then you just spray new stuff on.
I usually use paint thinner or some type of mineral spirits and a rag to get the tires clean initially but like I said if you use the NO TOUCH all the time you just wipe them clean with a rag.
I also use in my airdam and bumper impact strips as well as my mirrors.
Old 09-24-2005, 03:41 AM   #24
i use wesleys and it works to get the grime off. to make them look new, i use black magic tire wet foam and it keeps them black and shiny for a long time.
Old 09-30-2005, 10:54 PM   #25
crap
bg's's Avatar
Being the lazy ass I am, I got tired REAL quick of the Westley's bleach white. It worked
good on the tires, but getting that stuff off the rims was a PITA. Had to re polish etc.
So I went and got a can of the No Touch and tried it. I was pretty happy with the way
that stuff works. I screwed it up on the back tires as it got some runs in the stuff and
looks a lil nasty, so I'll redo em tomorrow.
No Touch makes three different kinds. The stock stuff in the white and red/black can,
then this stuff they call extreme wet, and the last is this new stuff they call ultra extreme
wet. I just wanted em back to black, so I got the stock stuff.
Have to admit I'll use No touch from now on. Works good, and it's easy to apply.
Thanks for the heads-up on the product.
Old 10-01-2005, 12:33 AM   #26
Get some A2Z or eagle one all wheel cleaner. Safe for aluminum non clear coated wheels and then some.
Old 10-02-2005, 01:24 AM   #27
ANGRY BABY!
Metlhed01's Avatar
dupont teflon wheel and tire cleaner works wonders as well. their tire shine works pretty good too.
Old 10-11-2005, 11:58 PM   #28
lilredxtreme's Avatar
Werd! simple gerrn is the shit. I now buy it by the gallon. I have never used it to wash the entire truck though. NEVER use it on a soft bed cover... I learned the hard way.
Old 10-12-2005, 12:28 AM   #29
ANGRY BABY!
Metlhed01's Avatar
yeah dont use it (strong) on interior plastics either...bleaches the hell out of em. same with 409.
you would think i would've learned my lesson...
Old 10-12-2005, 02:22 AM   #30
bagged1
dropped1's Avatar
ack...don't use simple green to wash the truck itself!! It will strip ANY protection there was off. I suggest using a quality car wash soap on normal washes and DAWN Dish Soap to strip old wax/sealants off before applying a new layer of wax/sealant.
Page generated in 0.62374 seconds with 31 queries
[Output: 139.15 Kb. compressed to 127.51 Kb. by saving 11.64 Kb. (8.36%)]
