Sticker Residue
Old 08-28-2005, 03:50 PM   #1
WARNING: Bad Habits
Driving4Life's Avatar
Sticker Residue
I see lot for getting it off paint but i didn't see any for getting it off glass without damaging the glass. So...
I removed that huge ass sticker on my rear window but, I don't know the best way to get the rest of the residue off without damaging the tempered glass. I took it off because it was blocking my vision. Any help other than "run a search" would be appreciated.
Old 08-28-2005, 04:02 PM   #2
.:|Hustlin4life|:.
dirttysouth's Avatar
Re: Sticker Residue
Is it on the outside? If so, take some rubbing alcahol on rag and rub over it (soak it down real good), then before it drys up take a lighter a nd light it (don't worry the alcohol burns quick it only burn for about 2 or 3 seconds, if not just bolw it out) and then scrub it with the rag and it should come right off. If you don't want to set it on fire the alcohol will take it off, you just have to scrub harder.
Old 08-28-2005, 04:15 PM   #3
3dme's Avatar
Re: Sticker Residue
a sharp razor blade, and scrape it off carefully, it has always worked for me
Old 08-28-2005, 04:39 PM   #4
It worked for Superman
Grinch78's Avatar
Re: Sticker Residue
WD-40 always works for me to take off sticker residue. Then you just use some Windex to get the WD-40 off.
Old 08-28-2005, 05:23 PM   #5
WARNING: Bad Habits
Re: Sticker Residue
K thx.
Old 08-28-2005, 07:19 PM   #6
Re: Sticker Residue
Its the best stuff for sticky left over residue. I used it for the residue left behind my badges.
Old 08-28-2005, 07:22 PM   #7
So long Patches
rattmobbins's Avatar
Re: Sticker Residue
Goo Gone. They sell it at Walmart. Works like a charm.
Old 08-29-2005, 12:59 AM   #8
Grinch78's Avatar
Re: Sticker Residue
Yeah same here. I used it on my badges, side molding, and vinyl stickers. Works great every time and Windex takes off the film it leaves behind with no problems. Everybody has a can of WD-40 so there is never a need to run to the store for it.
Old 08-29-2005, 10:12 AM   #9
Useless posting member
Wrkn prgs's Avatar
Re: Sticker Residue
I use that for everything.
Old 08-29-2005, 10:57 AM   #10
FuelJunkie.com
STXS10's Avatar
Re: Sticker Residue
WD-40 for PRESIDENT!!
Old 08-29-2005, 01:29 PM   #11
Hen oida hoti ouden oida
LoWeReDX10SiVeLy's Avatar
Re: Sticker Residue
razor blade & invisible glass....
Old 08-29-2005, 07:53 PM   #12
buellwinkle's Avatar
Re: Sticker Residue
Carefull with Goo Gone or Goof Off, use as little as possible and wash it off with soap quickly as it does dull the paint underneath, that's why I prefer a cleaner/polish like Meg's ScratchX or a milder lubricant like WD40.
Old 08-29-2005, 09:09 PM   #13
CHANGE YOUR EMAIL ADDRESS
Re: Sticker Residue
I work at a sign shop, windex and a scraper always works for me!
