Stain Cleaning Tip!
I thought I'd post another tip up here for those that have a nasty red or any bad stain that you cannot seem to get out (this works for red stains that have been sitting a long time).
When detailing cars we use something called a Vapor Steamer to clean interiors, engine compartments, etc. It's just a steamer that lifts dirt and cleans without the use of any chemicals. Most people cannot afford a $1000-$2000 dollar steamer. Here is something you can use on a red stain. Get a few plain white towels (hand drying,yo wash cloth, whatever u have). Get the towel damp, pull out your iron for ironing clothes. Turn it on, lay the towel down on the stain (make sure it's damp), hit the iron on top of the towel and even hit the steamer button a few times. Be sure not to leave it on too long or else it will get too hot and burn the towel and carpet or seat. The steam and heat will actually lift the dirt and stain up into the damp towel and the steam actually kills any bacteria or mold in the carpet without the use of chemicals. Keep turning the towel as it turns red until the stain is gone. You can vaccume and put some carpet cleaner on the stain first to let it sit which will help lift the dirt/stain. Hope this helps! |
I RIDE LO
Re: Stain Cleaning Tip!
cool. good tip!
Moderator
im gonna need to try this.. i have tan/beige carpet and its been nasty since ive gotten it.
will detail for food
NOTE: Rd stains that have been improperly cleaned and/or in the fabric/carpet for a long time, will be almost impossible to remove. You can lighten it. Also, another tip, while scrubbing a stain..... Scrub from the outer edge of the stain to the center. Scrubbing from the center out will spread the stain... happy detailing |
Good point, he is correct. Before doing this process be sure to vaccume the carpets well first and hit with a cleaner/shampoo, let it sit, scrub from the outside in, vaccume again and then hit it with the iron or steamer.
I AM CANADIAN
I solved this problem, Leather seats FTW.
On a serious note.. good tips ![]() |
Moderator
ah.. the carpet has been stained like it is since i got the blaze a little over a year ago.. ill still try it. im not super worried since i dont have floor mats and it will get dirty again
UN-BANNED B!TCHES!!!!!
Yes I have heard of people using that, I have not used it personally but hear it works. Before buying, try dilluted degreaser first.
i have and it does work.
