Rubbing compound....?
Thinking about using some rubbing compuond to take off alot of the scratches on my clearcoat. My question is what order do I used to do a good job. What I'm thinking is..
1) Wash 2) rubbing compound 3) clay bar? 4) polish? 5) wax? Got some overspray so I know I need the clay bar but I don't know if I need it if I'm already using the rubbing compound. I bought a Rockford 10" polisher/buffer yesterday at Wallmart (cheap $20 bucks) so I'm ready to get to work. Also, the rubbing compound I found at AutoZone where 2 made by turtle wax. One which was white, said for light to medium scratches and the other which was reddish burgandy said something like for medium to ? I tried that one on a small part of the truck with a towel and it seemed to LEAVE scratches and didn't take off any overspray Any suggestions would be appreciated! BTW, I did check out the HOW TO: care for your paint but it didn't mention the compound. Last edited by Swift12 : 03-10-2007 at 06:01 PM. |
Re: Rubbing compound....?
One more thing, Is "scratch off" a rubbing compound and if so would that work?
Thanks. |
www.oaktowntrucks.com
well i like to use what's called ""system one" Welcome to SYSTEM*ONE*products web site
that is what we use in the body shop but sense you are just trying to get some shine her up any brand name rubbing compound will work 3m you can never go wrong with you will get your best look if you go over the hole thing with 2,000 wet sand, but it will take a little more then just a top finish glaze i hope that helps |
drunk and bored
just go get some 3m compound...lol
that's all i use so i make no other recommendations |
Low in Alaska
why isn't your name green anymore, joe?
and if you wet sand you will have to do more wheeling, but with your $20 buffer i don't thing it will spin fast enough so just get any brand name polish and go at it so 1) Wash 2) polish 3) use a swirl remover 4) use a detail spray to top it off if you use a polish you don't need to wax |
drunk and bored
yea it was probably to much work
now just sit back and enjoy the ride oh that is what she sad |
crap
I'm going to try some of that compound Paint Toad uses. I hope a little
goes a long way because it ain't cheap. 30.00 bucks for a qt, 99.00 for a gal..3M must be really proud of their products. |
