restoring faded single stage paint(huge pics)
Old 01-30-2007, 09:27 AM   #1
drunk and bored
Sir Toad's Avatar
restoring faded paint on a mazda b3000(same as a ford ranger)first wash n dry the vehicle...inspect for tree sap/road tar..
use Malco adhesive and label remover:
http://i58.photobucket.com/albums/g2...dab3000019.jpg
to remove tar:
just dampen a towel with the product then hold on contamination to soften,then lightly rub
tar's gone:
you will find more as you buff,the lighter stuff you can buff off,the heavier will require more cleaner(btw you will find a TON of uses for this cleaner.
ok this is the compound 3M Perfect it 3000 rubbing compound(can also be bought in quarts):
what you want to do now is take a 'soft' towel and compound and rub,by hand areas that will be difficult to reach by machine:
now that that's done get ready to buff with the wool pad:
and the compound
i buffed at about 12-1400 rpm
do you see the compound between the pieces of tape?
that will do that square area between the tape/bodyline/wheel well
use medium pressure,just lightly pass over all the areas you did by hand
i don't throw away old buff pads just for this reason,when they get to wore out for a fresh paint job i put them away for a project like this:
i used front n back of 3 pads(the roof took both sides of one pad:
after you are pleased with your buffing,wash with soap and water and dry thoroughly,you do not want even little drops of water on the panels as it will make removing the polish a real pain
here's the polish (3M perfect it 3 Machine Glaze) and pad #'s:
you already saw a pic with a good view of the numbers,this is to show the backing pad for the polishing pad.
i did not get a pic,but remember the compound between the tape?it will take 1/4-1/2 the amount of polish to do the same area.keep a NEW soft towel to rub off polish that dried before you could remove with the pad
if you look careful,you can see the upper left 1/4 of the tailgate has been polished...see how the rest is pinkish/hazy?
polish with medium pressure,gradualy using lighter pressure till the haze goes away.
now wash,dry it,wax it and enjoy a shiny vehicle
i did not remove all swirl marks from the wool pad because i really didn't care at this point,as it is a used truck,going to the lot,and it is getting a good coat of wax from the detailer.
i sure there will be questions,that's what i'm here for i don't use any products other than 3m
Old 01-30-2007, 09:30 AM   #2
drunk and bored
Sir Toad's Avatar
Re: restoring faded paint
http://i58.photobucket.com/albums/g2...dab3000049.jpg
Old 01-30-2007, 09:32 AM   #3
drunk and bored
Sir Toad's Avatar
Re: restoring faded paint(huge pics)
please bear with it until i reformat it
Old 01-30-2007, 09:48 AM   #4
PUNISHING GROUNDS
got_u_sick's Avatar
Awsomeness! Subscribed.
Old 01-31-2007, 05:08 AM   #5
dillon_b12's Avatar
How much do you charge for a job like that?
Old 02-03-2007, 12:31 PM   #6
Gots me a 4x4 too!
DropNDestroy's Avatar
Wow, that is amazing! NIce work PaintToad
-Parker
Old 02-03-2007, 09:34 PM   #7
DIMEond
chevs1091's Avatar
nice job man- i have done a few projects like that myself- its very time consuming- single stage paint sucks!
Old 03-07-2007, 11:15 AM   #8
FloridaTruckScene.com
SaltyOnionBalls's Avatar
This is awesome, I am going to try this soon on my new DD.
How much did the materials cost you?
Old 03-07-2007, 12:19 PM   #9
drunk and bored
Sir Toad's Avatar
about $100
Old 06-05-2007, 11:02 AM   #10
Broken Handed Superman
MeltingPlastic's Avatar
toad, do you use a rotary or orbital buffer? i have a rotary one and i'm affraid to ruin my paint with it. any tips?
Old 06-05-2007, 11:47 AM   #11
The other "body" man
BobOnAir's Avatar
Don't hold in one spot,, you'll over heat your paint and blister it! Trust me,, I know,, I had to repaint the rear door of our hearse because I wasn't paying attention!
Old 06-05-2007, 01:41 PM   #12
drunk and bored
Sir Toad's Avatar
i use a rotary buffer.....and always keep moving
Old 06-05-2007, 01:51 PM   #13
any tips on motions to use? ive heard an arching pattern back and forth is good. and i know not to let the foam pad go on its edge and that stuff.
Old 06-05-2007, 08:19 PM   #14
drunk and bored
Sir Toad's Avatar
i use a wool pad.....just use slow,steady sweeping passes......use 50% overlap almost like you are painting
i'll grab some pics tommorow of a vette i'm buffing out.......looked the same as the truck although the 'vette is base/clear
Old 01-05-2008, 07:50 PM   #15
silvern1055's Avatar
looks awsome toad where can you get that malco at the local paint shop
Old 01-06-2008, 12:17 AM   #16
drunk and bored
Sir Toad's Avatar
yeah
Old 01-06-2008, 12:05 PM   #17
kewl thanks
Old 01-06-2008, 12:35 PM   #18
damned 4banger
Noremac's Avatar
that looks awesome toad... i had ran over a thread where a guy was detailing an audi r8 and this made me think of that lol.. i can dig it back up if you wanna see what a VERY expensive european detailing job looks like
Old 01-06-2008, 05:56 PM   #19
drunk and bored
Sir Toad's Avatar
i don't care about detailing...been there done that, in my rookie days......i've moved on
Old 01-06-2008, 08:32 PM   #20
Banned
awesome! i need to do this to my drivers door and 3rd door. they have faded paint on them and only them for some odd reason. i think they were repaint and never cleared. the doors just look funny. when the truck is wet all the paint looks great. once dried the doors are light in color and look like they are 10 years older than the rest of the truck
Old 04-29-2009, 03:31 PM   #21
"SHOW TIME PRIME"
mccord's Avatar
i c buffer trails
Old 06-27-2009, 04:37 PM   #22
drunk and bored
Sir Toad's Avatar
Quote: Originally Posted by mccord
i c buffer trails
maybe you should go back and READ!!!!!!!!!
Old 01-07-2010, 04:06 PM   #23
Re: restoring faded single stage paint(huge pics)
wow thanks man im going to have to try this on my 90 f150.
Old 01-07-2010, 04:39 PM   #24
since this topic is already bumped, to remove those buffer trails and holograms, would you switch to an orbital such as a PC and but them out that way? or is there tricks to getting a hologram free finish with a rotary?
Old 01-10-2010, 12:34 AM   #25
Short Bus Anonymous
wagonproject's Avatar
You "shouldn't" have holograms/buffer trails to begin with. Yes you may get them at times with some more agressive compounds, but you just need to keep stepping down the compounds/polishes until your at a "finish" polish. Generally there caused by going to fast with the buffer, to much/not enough product, pad not being flat, not working/over working the product, and possibly to much pressure. Some people like to use a DA on there finishing step as they say its "easier" to finish out. I bought a DA to try after reading about it for a while after I had been using a rotary for a few years. Used it a few times and haven't touched it in a few years. Didn't think it made it any easier to finish off. Just personal preference I guess. Generally I like to keep the RPM under 1000 for my final polishing. Use very smooth, slow passes.
