Repaired a scratch, how to I make it blend in?
Old 04-12-2006, 08:39 PM   #1
Sportbike Nut
So I had a roughly 2" square scratch on the tailgate. I got the correct color spray paint and clearcoat and finished that yesterday. Matches fairly well, but you can still see the edges that were taped off. And the paint is a little faded after 9 years. Is there a good buffing compound or something to make this blend in? Do I just polish it, or do I have to wetsand it? Thanks
Old 04-12-2006, 08:46 PM   #2
tuckin' fx4
zachmartin83's Avatar
Re: Repaired a scratch, how to I make it blend in?
what kind apaint did u use like spray touch up paint i really hate the brush on touchup paint and i have some big scratches i wanna fill in
Old 04-12-2006, 09:09 PM   #3
Photoshop Fiend
ACE2790's Avatar
I got some dupont touch up paint with a PEN tip. Worked really good for small chips and thin scratches. well recommended for quick touch ups for only 3 bucks and some change.
Old 04-12-2006, 09:11 PM   #4
95projectS-Dime's Avatar
taoing lines are almost impossible to blend , should have just blended the paint and not taped it ,,GOOOD LUCK
Old 04-12-2006, 09:19 PM   #5
s10nospeed's Avatar
its just the gate, paint the whole damn thing
Old 04-12-2006, 09:44 PM   #6
S-Clusive's Jester
TruStinger's Avatar
if its just in the clear you can colorsand and buff but if its all the way through take it down with 400 until the scratch is gone and then feather the edges out. scuff up the clear on the whole gate with 400. then when u spray base just hit the area that needs it and do some overlap onto the surrounding area. with each coat spread it out more. so like 6-10" radius around the scratch. and then reclear the whole thing
Old 04-13-2006, 01:23 AM   #7
SVT Cobra Moderator
Offthehook's Avatar
moved, hopefully you will get better help in here
Old 04-13-2006, 01:42 AM   #8
Sportbike Nut
Thanks for the help guys. I'll try and sand it out then. What do you mean by color sand? Is that wet?
Old 04-13-2006, 07:22 AM   #9
Yes , wet sand
