Removing road paint
Old 08-21-2004, 07:44 PM   #1
Removing road paint
I've got this stringy white stuff that looks and feels like rubberized paint all over the left side of my truck. I think it's the paint used on asphalt (assuming the rubberized compound works better). Any idea on how to get it off?
I'm about ready to use a little acetone on it...
Old 08-21-2004, 08:00 PM   #2
BlazinOn18s
Proballer25's Avatar
Re: Removing road paint
No dont.. Go to autozone and buy a CLAY BAR with Lubricant. You simply spray the lub onto the panel and rub the clay bar in a back and forth motion. Then whipe clean with a towl. try this and let me know if it works.
Old 08-21-2004, 08:32 PM   #3
Ok. This is probably what I will do. This stuff is hellathick though, so I'm concerned that the clay just might not do it. I've been doing some reading, and guys use mineral spirits a lot to get rid of various materials. This should not be _too_ different from acetone, although acetone is an organic solvent, not a petroleum one. Any ideas?
Old 08-21-2004, 08:48 PM   #4
Well, I went ahead and tested the acetone - it works, but I'm a little concerned that I may be removing more than I want to, so I'm gonna go get some mineral spirits. Report back later.
Old 08-30-2004, 01:47 AM   #5
3M ADHEAVSIVE REMOVER. goo gone mild version
Old 09-03-2004, 02:49 PM   #6
I'm probably drunk.
BLAZ1N's Avatar
whatever you do wax it right after
Old 07-13-2006, 07:04 PM   #7
De-extremed S-10 Sonoma?
Old thread, but a similar question.
Only, my problem is that I just finished painting a week ago using the Hot Rod Flatz midnight blue. I've got white road paint all over my fresh paint and I'm worried about using anything, even a clay bar on my fresh blue sealer. I roughed up the original paint to 320, primed with a filler primer, and then sprayed the hot rod flatz. Do you think mineral spirits or the clay bar will take off the top coat?
Old 07-13-2006, 07:05 PM   #8
Oh, and I sanded the filler primer w/ 400, wiped it down, and tack-ragged before spraying the blue.
Old 07-15-2006, 07:54 PM   #9
MsLowS10's Avatar
for tar and road pant use 3812 adhesive remover works really well with out recking the paint but wax after though
Old 07-16-2006, 02:02 PM   #10
Umm, I can't wax it after . . . It's flat blue LOL. Hopefully the adhesive remover won't take off the primer. Thanks.
Page generated in 0.59238 seconds with 31 queries
[Output: 67.84 Kb. compressed to 63.46 Kb. by saving 4.38 Kb. (6.46%)]
