Have you seen my glovebox
removing pinstrip
This truck i am getting has this gaudy gold pinstriping along both sides and i want to take it off.. what is the best way?
RUB A DUB
Re: removing pinstrip
is it cleared over?
Hates 'know-it-alls'
if it's not cleared over, and I doubt it is, you can use a hair dryer or heat gun to warm it up a little bit. Then peel it off, then use an 'eraser wheel' to remove any leftover residue without hurting the paint or clearcoat
no they are just on there.. thanks i will get right on this
Domestic newbie
also 3m adhesive & tar remover, lighter fluid, or laquer thinner will do a good job at getting the glue off. Wax over the area when you're done.
thinner nor recommended for just getting glue off but if u use heat gun most will come off u might need to use wax and grease remover for left over residue then if u still see line where it was u might need to buff
i looked today and it has no pinstripping
i am so glad that is off my mind.. but what i really need to worry about now are these gay ass rims *UUGGHH* |
