Rockin' the vinyl
Removing Lund window trim
Well, I just cracked one of the window rain covers (i don't know what they're actually called) when I was shoveling the 3 feet of snow off. The truck came with them, and I'd been lazy about taking them off, but now they've got to go. How do I take them off? The 3M glue or tape or whatever it is happens to be sticky as hell. Any sort of solvents out there that will make things easier?
Dave
Re: Removing Lund window trim
use a razorblade to seporate the foam tape from the guards, NOT the tape from the truck, and get them off.
then peel the tape off with the help of goo-gone. Last edited by Dave1814 : 01-23-2005 at 07:13 PM. |
Rockin' the vinyl
Sweet, thanks. I'll try that today.
MPG is overrated
heat the tape up with a hair dryer or heat gun, pull a fishing line under it.
Finally got a radio
use laquer thinner and rub it with a rag. the razor technique is good but it is VERY easy to cut into the rubber. so be careful
Finally got a radio
ok I HAVE FOUND IT, my old way didnt work and took tooo much time. there is a rubber wheel called an eraser. you hook it to a drill and it'll spin the foam right off. works great, but it makes the foam go every where so make sure your windows are up.
