Removing bugs and tar?
Old 07-27-2006, 09:46 PM   #1
Seeking Insight
neuronyx's Avatar
Title says it. Whats the best stuff I can use, which is NON abrasive? I used some rubbing compound, and man did that haze the paint up, even after a wax!
How about on plastic?
Old 07-27-2006, 09:47 PM   #2
It's a Blue thing...
♠ M®. ßlυε ♠'s Avatar
Re: Removing bugs and tar?
Soap and water?
Old 07-27-2006, 09:52 PM   #3
Seeking Insight
neuronyx's Avatar
Didnt have too much luck with that, especially the tar spots. Anything that is a little stronger?
Old 07-27-2006, 09:58 PM   #4
Senior Member
well first of all most compounds are abrasive so YA its gunna haze up no matter even if you waxed it, you have to polish out the compound haze.
secondly, if your bugs are not "coming off" its probably bug etching that you have there.
what happens is this:
say your driving down the road.........
SPLATT
a bug hits your hood/paint well that bug just exploded and now theres bug GUTS on your paint well, bug guts , like ANY guts have ACID in them and that acid will eat thru your clear and paint and leave a "splattered bug" look to it (moral of this story is to remove bugs ASAP)
sooooooo
get pics of your "bugs" and ill tell you if they will come off or not.
Old 07-27-2006, 10:11 PM   #5
Seeking Insight
neuronyx's Avatar
Ill have to grab them later, its dark now. Theres only a few bad ones, that I think should come off.
What should I use on the haze btw?
Old 07-27-2006, 10:16 PM   #6
Senior Member
a polish.
well if youve tried and they havent come off they are probably etched.
oh and also get a netted bug sponge at like wal-mart that might help
Old 07-27-2006, 10:17 PM   #7
Senior Member
double post
Old 07-27-2006, 10:17 PM   #8
Senior Member
triple post
that damn edit and reply button are to close together!!!
Old 07-27-2006, 10:20 PM   #9
Seeking Insight
neuronyx's Avatar
Allright, thanks for the tips s10 user. I guess any polish will do. Luckily the areas that I used the compound on are pretty well hidden (IE not directly on top of the hood). Also had to remove A LOT of pine sap, because I am also using my S10 as a work truck to haul all sorts of fun things that destroy all that time spent on detailing, very quickly. Next is to rhino coat the bed, and cap the sides!
Old 07-27-2006, 10:23 PM   #10
Senior Member
FYI:
the difference between a WAX and a POLISH is :
wax is a protectant.
polish is a cleaner.
so make sure the bottle says "polish"
also try rubbing alcohol on tree sap. removes it almost immediately
Old 07-27-2006, 10:29 PM   #11
Seeking Insight
neuronyx's Avatar
Allright, thanks. I kind of figured that, considering carnuba wax really isnt abrasive.
Old 07-28-2006, 01:26 AM   #12
ZR2 member
Scott01's Avatar
Get one of these.Sponge covered with webbing.Also works grat getting grime off lower rockers and cleaning tires.
Old 07-28-2006, 02:09 AM   #13
Seeking Insight
neuronyx's Avatar
Thats ironic how it says bug and tar remover.
Thanks Scott!
Old 07-28-2006, 02:11 AM   #14
Blacknoma's Avatar
use a fabric softener sheet (the ones you put in the dryer) to take off bugs. just wet it a little and it takes bugs off surprisingly easy
Old 07-28-2006, 02:14 AM   #15
Seeking Insight
neuronyx's Avatar
Thanks for the tip blacknoma, I will give that a try too.
Sweet ride btw!
Old 08-03-2006, 06:32 PM   #16
crap
bg's's Avatar
People that make Seafoam engine cleaner also make a
really nice bug remover..
http://www.seafoamsales.com/products.htm
Old 08-06-2006, 02:22 AM   #17
bug and tar remover spray let it soak 5 min they wipe off like dust
Old 08-06-2006, 12:56 PM   #18
De00vize's Avatar
You could always claybar it although it is alot of work!
Old 08-06-2006, 11:08 PM   #19
Rustbucket Club
LikeaRock's Avatar
Not all polishes are cleaners. There are cleaner polishes out there, but most polishes remove surface imperfections
The way I get rid of bugs is a quick pre-soak with Simple Green diluted 8:1 with water, then I hit them again with a bug mitt LIGHTLY (the netting can marr your clear very easy), rinse and usually they come off. This method works for tar but I usually use lacquer thinner for any road tar. Adding a glaze to your rocker panels after each wash can also help keep tar from sticking to the paint
Old 08-07-2006, 02:20 AM   #20
Seeking Insight
neuronyx's Avatar
Simple green I do have. Maybe Ill give that a try on some of the areas. Havent taken a look at my auto store to see if they carry anything that is specifically made for bugs and tar.
Im not that particular to use a clay bar. Thats too much work for a truck that I use at work. Ends up being a dusty muddy mess in a week anyway.
Old 08-09-2006, 01:39 AM   #21
ive got some stuff sitting in my garage and its called "bug and tar remover" comes in a can, its like a polish i guess but it works great
Old 08-09-2006, 03:34 AM   #22
alex
idirtjump's Avatar
its as easy to use wd-40 just spray it on the tar and let it sit for like 2 min and it just whipes off if its not all gone just do it over
Old 08-09-2006, 10:07 PM   #23
Seeking Insight
neuronyx's Avatar
WD-40 works well at getting bubble gum off too.
I have a few strange spots that look like this:
Looks like the clear coat is a little cracked or something:
Then there are the ones that look like this.
Old 08-10-2006, 05:52 PM   #24
2nd one should buff out. Is that metallic or pits in the paint
Old 08-10-2006, 09:44 PM   #25
MastaE1024's Avatar
i parked under a pine tree for a day and sap got everywhere, i used bug & tar remover and it did nothing, then i used laquer thinner and took almost all of it off along, but there are a few spots where it dried, what should i use to get it off??
Old 08-10-2006, 09:59 PM   #26
Seeking Insight
neuronyx's Avatar
Those are defects in my clear coat. Not too sure what happened there.
Old 08-20-2006, 11:14 AM   #27
now XTREME
94redSS's Avatar
stoner makes AWESOME SHIT! also
Old 08-20-2006, 11:21 AM   #28
yeah yer mom liked it
low-s-dime's Avatar
go down the cleaner and polish isle in any car parts store...dont even need to use the search button
Old 08-21-2006, 04:27 PM   #29
MastaE1024's Avatar
goof off is your friend!!!
Old 09-06-2006, 11:28 PM   #30
3m adhesive remover i used to work @ a dealership and that was all we used to take tar and bugs off when scrubbing wouldn't. For tar let it sit and spray it on heavy and watch it run the spray it again the wash w/soapy rag repeat till all tar and bugs are gone
Old 09-07-2006, 06:32 PM   #31
Seeking Insight
neuronyx's Avatar
Figured a good way to remove the bugs, well the really bad spots. 3M polishing compound does wonders. Make sure to use a 3 cut though. Any more than that and you will mess that clear coat up.
As for goo gone, yes that works as well. HOWEVER do NOT get that near any plastics. It will melt them within seconds. I made that mistake when cleaning my 3rd brake light.
Old 09-11-2006, 12:28 PM   #32
crim's Avatar
SPLATT
sooooooo
i think this has happened to my paint...ill get a pic but if so what is the soloution...new paint??
Old 09-11-2006, 11:48 PM   #33
bagged85's Avatar
i just use bug and tar remover, its in a black bottle and another one with wax mixed in a green bottle, works wonders (dont get it on the window)
Page generated in 0.63962 seconds with 31 queries
[Output: 148.74 Kb. compressed to 136.02 Kb. by saving 12.71 Kb. (8.55%)]
