Under Construction
removed tweed, what the clean the glue?
I pulled tweed off some plastics that I now plan on painting. What can I use to clean the spray glue off?
Work in Progress
Re: removed tweed, what the clean the glue?
i would say just sand em? you're going to have to sand the plastic anyways.. or use a putty knife.. or you can maybe use goo gone and make a gooky mess
I used the goo gone spray worked real good. Its like 7 bucks a can..
4 Bangin'
they make pnuematic erasers you could use, or paint thinner, or goo gone. lots of stuff will work
Ex-Import Lover
look into finding smoe stuff called, Rapid Remover, when i worked at this vinyl shop, we used that to get the adhesive from teh vinyl off. Then cleaned the piece with Methyl Hydrate. its how i cleaned my windows after i took off the tint.
This "Aircraft stripper" stuff you can buy at walmart and most auto stores works good for removing any adhesive/paint/etc. but, be careful with it, it is powerful, and it will take off all kinds off other clear coats, and whatnot.
