Removed Embelems ... LOOKS HORRIBLE!!!
Old 08-07-2005, 05:47 PM   #1
Teen Member
bigphill911's Avatar
Exclamation Removed Embelems ... LOOKS HORRIBLE!!!
Hey guys a little while ago I removed all the embelems from my black 94 sonoma. Everything turned out good other then the 2 back embelems. After I took them off and used a hairdryer and some goo gone to get them off then washed it up it left really bright spots where they were. You cant see the spots at all whenever the truck is wet but when its dry and the sun hits it it looks horrible? Is there anyway to fix this or am I screwed? Thanks for the help ahead of time. The picture below is what it looks like dry with the sun shining on it. You cant tell in the pic of the left side decal but you can on the right side decal.
Old 08-07-2005, 05:49 PM   #2
#2 Post Whore
Bennelton's Avatar
Re: Removed Embelems ... LOOKS HORRIBLE!!!
take it to a body shop and ask them to detail it or buff that part out
Old 08-07-2005, 05:50 PM   #3
Photoshop Fiend
ACE2790's Avatar
Well my truck is a 2000 so when i took mine off it was a lil rough at first but it got better with time, now its all good. But imma guess some wax of some kind. Maybe a polish or the black turtle wax? theres supposedly a 3M rubbing compound out thats really good on scratches and stuff but i cant find it.
Old 08-07-2005, 07:34 PM   #4
Function Over Form
Powerman's Avatar
Yup I did the same on my boat and we do this at work(collision center) when people have those magnetic or stick on things on the side of there trucks for buisnesses. Get some rubbing compoound and a buffer(or go to a bodyshop and they will do this) and have it buffed and polished and you'll never be able to tell they were there.
Old 08-07-2005, 08:43 PM   #5
now XTREME
94redSS's Avatar
yea dude that will buff right out
Old 08-08-2005, 11:56 AM   #6
buellwinkle's Avatar
Get a tube of Meguiars ScratchX and put some elbow grease behind it and do multiple applications until it's to your liking.
Old 08-08-2005, 12:03 PM   #7
chevyoverford43's Avatar
Ya that goo-gone you used ate up the clear coat. If that happened then there is no buffing out. You might have got lucky and it could be on top but I doubt it, hard to see form that pic.
Old 08-08-2005, 10:25 PM   #8
Rustbucket Club
LikeaRock's Avatar
Never use Rubbing Compound on a clearcoat finish unless it states that it is clear coat safe, like 3M Fine Cut.
I'd clay the entire tailgate, then follow up with some sort of semi-abrasive polish, like Megs Scratch-X or some sort of polishing compound, then a final coat of wax. It might not hurt to use a paint cleanser too, like Megs Body Scrub. And all these products are available at almost any auto parts store
Old 08-11-2005, 02:17 AM   #9
!!SNOOGENS!!
Xtreme27's Avatar
Yea that scratch x came from gods ass i swear cause that stuff works miracles!!!!!
Old 08-13-2005, 12:04 AM   #10
<Insert Title Here>
99ZR2's Avatar
I don't see how Goo-Gone would of done that to the tailgate though. The reason I say that is because I think lots of people use goo-gone, and never have that problem. I used it as well when I removed my emblems, no problems w/ it. I dunno though, just saying what I know.
Old 08-13-2005, 12:17 AM   #11
Hen oida hoti ouden oida
LoWeReDX10SiVeLy's Avatar
I was thinkin that from teh get go.....
It's probabaly just some residual adhesive that has dried on top of the clearcoat.... clay it to remove the crap that's still on there, use teh polish, and mebbe a little cleaner wax before you put a final coat.....
Old 08-13-2005, 12:29 AM   #12
Mmmm Tire smoke.
indigo s10's Avatar
Old 08-13-2005, 10:29 PM   #13
Useless posting member
Wrkn prgs's Avatar
You didn't happen to scrub it with anything did you?
Old 08-14-2005, 12:46 AM   #14
limeade
01black4.3's Avatar
Oh good, I was planning on removing mine with goo-gone, but now I dont know what to use? Heat and fishing line, but what to use to remove the glue?
Old 08-14-2005, 12:50 AM   #15
notalifestyle
itsalifestyle's Avatar
go get some 3m perfect it 2.
Old 08-14-2005, 12:58 AM   #16
The other "body" man
BobOnAir's Avatar
Well,,, this is what I would do...
since I have a buffer,, and I have different compounds,,
I would use a pre wax cleaner, or the mothers clay bar system first,
then I would use 1500 grit with cutting compound pad and buff the area.
then I would use my polish compound, I think it's around 3000 grit, with the proper pad,
then follow up with wax and buff to shine!
so, that's me,, if you can get a hold of a buffer! do that!
Old 08-14-2005, 02:31 PM   #17
FuelJunkie.com
STXS10's Avatar
werd i used that when i pulled off mine
Old 08-21-2005, 04:06 PM   #18
Lifted BlaZer
96Blazer4x4's Avatar
take a hair dryer to get the glue hot and mine came right off
Old 08-21-2005, 05:11 PM   #19
Beyond Basic.
Basic's Avatar
wow, that looks familiar...
take it to a detailer.. 20$ if you cant do it yourself.
comes out like..
I thought it was literally ****ed to. until it was buffed out and I was like
Old 08-21-2005, 07:14 PM   #20
98' Cowl Induction
GiveMeBreak's Avatar
once the emblem is off
hit the sticky tape/glue with this (local wally world has it)
Then follow up with Scratch X...and if you have a buffer...buff then wax...if not the scratch x
and wax should do it up nice.
My truck is debadged, de pinstriped, de side molding and CLEAN as a whistle!
Old 08-22-2005, 02:05 PM   #21
resU deretsigeR
Woodward05's Avatar
I Used A Credit Card To Scrape It Off And Then Just Rubbed really Hard With Some Wet Washcloths
Old 08-26-2005, 05:28 PM   #22
redrider's Avatar
what is the best/easiest way to debadge?
Old 08-28-2005, 06:18 AM   #23
[quote=LikeaRock]Never use Rubbing Compound on a clearcoat finish unless it states that it is clear coat safe, like 3M Fine Cut.
You can use any rubbing compound on any clear coat finish it is just the technique of applying it. Knowing how much clear is on there, how thick.
Old 09-16-2005, 11:30 PM   #24
DeMiN
BWAceo2's Avatar
I noticed that some of the newer cars have little poles going into the sheet metal and some are all adhesive. I drive a 1996 s10 and I was wondering if it was all held on by just adhesive? Thanks guys.
Old 09-17-2005, 05:24 PM   #25
Teen Member
alright well the spunge i used was kinda gritty i think I might have removed some clear coat SHIT what should i do?
Old 09-19-2005, 08:25 AM   #26
redrider's Avatar
ummm.....since u photoshoped that pic, dont u think u should have taken the dent out of the door?
Old 09-19-2005, 03:03 PM   #27
DeMiN
BWAceo2's Avatar
If you are talking to me, maybe I didn't photoshop out the dent cause there isnt one present.
Old 09-19-2005, 03:07 PM   #28
woof
whitedime's Avatar
i dont think he's talking to you dingus. the grey truck
Old 09-19-2005, 05:30 PM   #29
Teen Member
lol if ur talkin to me i didnt photoshop it i had someone do it for me lol
Old 09-19-2005, 11:37 PM   #30
Custom User Title
neel2008's Avatar
hey phill not to get off topic but its nice to see another teen like me on here doing what he can. I'm 15 from Huntington, Indiana (small world) not many people around here know what they are talking about, they're just a bunch of fvcking wiggers and people that all they want is a fvckin ricer in this town(i'm not one of em) and i think the best way is to start out young and do it right. keep on truckin'.
PS. Kill all ricers!
Old 09-20-2005, 05:01 PM   #31
Teen Member
hey man whats up? I use to live in Markle so we went to Huntington all the time. I go to Norwell idk if you ever hered of it or not? Its in Ossian which is really small and close to Bluffton.
Old 09-20-2005, 05:50 PM   #32
Custom User Title
neel2008's Avatar
hell yea i go to Huntington North we play u some times. are u on msn or anything i'm neel2008@hotmail.com. (sorry to all the other users for getting off topic)
Old 09-20-2005, 11:32 PM   #33
Teen Member
im on aim sometime bigphill911 yah man id be going to huntington north if i wouldnt of moved its a big ass school compared to norwell lol
Page generated in 0.73869 seconds with 31 queries
[Output: 150.26 Kb. compressed to 137.57 Kb. by saving 12.69 Kb. (8.45%)]
