Porter Cable 7336 or 7424
Old 04-30-2006, 09:40 PM   #1
Short Bus Anonymous
wagonproject's Avatar
My local Lowes has the 7336 for about $100 but not the 7424. Any advantages to getting one or the other?
Old 05-01-2006, 01:06 PM   #2
Canyon Carver
Re: Porter Cable 7336 or 7424
7424...
Features: 3.7 Amp, AC Only * Electronic variable speed 2,500-6,000 OPM * Random, swirl-free polishing action * Spiral/bevel gears * 100% ball & roller bearing construction * Standard Equipment: Polisher, polishing pad #54745, wrench #48779, side handle, & operating manual Specifications: * Power: 120 VAC, 50-60 HZ/120 VDC * Motor Amps: 3.7 * No-load Speed: 2,500-6,000 RPM * Spindle Thread Size: Accepts 5/16 - 24 * Gear Drive: Spiral Bevel * Wheel/Pad Size: 6" * Length: 11 1/2"
7336...
Features: 3.7 Amp, AC only * Electronic variable-speed dial 2,500-6,000 OPM * Random, swirl-free sanding action * Spiral/bevel gears * 100% ball bearings * Standard Equipment: Sander, PSA pad, abrasive disk, side handle, & operating manual Specifications: * Power: 120 VAC, 50-60 HZ * Motor Amps: 3.7 * Speed: 2,500-6,000 * Tool Length (inches) w/ Pad: 11-1/2
Looks like it's the same thing except for the pads. The 7424 is set up for polishing while the 7336 is set up for sanding.
Old 05-01-2006, 01:10 PM   #3
Choosy moms choose Jeff
bad03xtreme's Avatar
Get the 7336 I have it and it is much better becuase you can polish with the extra power you have and yo ucan slow it down to apply wax and such. I reccomend it
Old 05-01-2006, 11:24 PM   #4
Rustbucket Club
LikeaRock's Avatar
They're EXACTLY the same machine except for the counterweight. Doesn't matter which one you get, the perform the same
Old 05-01-2006, 11:58 PM   #5
bagged1
dropped1's Avatar
and you can get the correct counter weight if wanted...
Page generated in 0.56345 seconds with 31 queries
[Output: 54.16 Kb. compressed to 51.47 Kb. by saving 2.68 Kb. (4.96%)]
