polishing my billet grille
Old 03-20-2008, 01:20 PM   #1
BTE
I have no idea
BTE's Avatar
I never took my billet grille out of the truck when I moved up here to the great white north (stupid me), and it has started corroding.
I have tried Eagle 1 nano polish just because it's all I have right now, and it cleans it up, but you can still see marks from the corrosion. I usually use Mothers billet polish but I don't know if it will help in this stage. I'm thinking I may have to use some 1000-2000 grit paper and go from heavier to finer polishes.
Any ideas? all help is appreciated because I'm OCD about this kind of stuff
tia
Old 03-21-2008, 03:12 PM   #2
I RIDE LO
Kovz's Avatar
Re: polishing my billet grille
tia
if it were mine... id take it out and use a polishing wheel and some mother billet polish.
Old 03-21-2008, 10:39 PM   #3
BTE
I have no idea
BTE's Avatar
It's already out of the truck. I don't know, maybe im expecting too much. It won't be that noticeable if I just finish polishing it and put it back on. Maybe that is just normal wear and tear for a billet grill.
Old 03-22-2008, 03:35 AM   #4
UNDER CONSTRUCTION
Twin-10s's Avatar
if its that bad use some 1500 then 2000 grit wet/dry sand paper on it first. use it wet, them use some mothers billet polish. should come out like new.
Old 03-22-2008, 11:07 AM   #5
BTE
I have no idea
BTE's Avatar
Will the 1500-2000 grit leave scratch marks too deep to get out with the Mother polish??
Old 03-22-2008, 02:43 PM   #6
UNDER CONSTRUCTION
Twin-10s's Avatar
no it will be fine. us the 1500 then hit it with 2000 then the polish. i build small billet parts for myself all the time and polish them out this way. but i have to start with 600,800,1000.1500 then 2000. because I'm starting with raw material.
hell i did the the inside of my coddington wheels this way also, look great when done.
Old 03-22-2008, 04:14 PM   #7
lowNslo's Avatar
good to know thanks for the tip man
Old 03-25-2008, 11:42 PM   #8
Riding High 2wd
BillsDuster's Avatar
Try "never dull" its like a cotton material that is saturated with a polishing compound. With some elbow grease it will clean some seriously messed surfaces. I used it to clean up a bunch of corroded brass on the ship I work on. Brass-o and other cleaning chemicals wouldnt nearly make it shine like the NeverDull did. It will not leave marks on plated or billet surfaces, but dont use it on paint.
Page generated in 0.57052 seconds with 31 queries
[Output: 64.43 Kb. compressed to 60.65 Kb. by saving 3.77 Kb. (5.85%)]
