polishing cast aluminum?
Old 02-08-2009, 11:44 AM   #1
Project Classified LIVES!
dngrous_dime's Avatar
Okay, so I picked up a set of cast aluminum valve covers last night on Ebay, for my project. Anyone have any tips on polishing these fvckers? I'll try to get a pic loaded later.
Only certain portions will be polished, the rest will be powdercoated.
Old 02-08-2009, 12:29 PM   #2
what?
evanspears1's Avatar
Re: polishing cast aluminum?
Mother mag and aluminum polish... and considerable amounts of elbow grease... I polished a cast aluminum throttle body elboy for my talon, it took a couple of days of tv time polishing on that bastard, but mothers took it from charcoal gray, to nearly as shiny as my chrome intercooler pipes...
dunno what your wanting polished, but if it is accessible enough, try a buffer, or if its small stuff like the tops of letters, try a dremel with a polishing wheel...
I dont know if this is the fastest way to get a mirror polish, but I know it works good!
Old 02-08-2009, 01:10 PM   #3
bellcranks no more
greencactus3's Avatar
buffing wheel on a bench grinder
Old 02-08-2009, 01:11 PM   #4
My research online has led me to believe that a palm sander to take down the rough stuff will work, and then a set of buffing wheels with varying grit compounds will be the best way.
And I already said "cast aluminum valve covers". Just the flat surfaces and convex areas will be polished, the rest will be powdercoated a yet-to-be-determined color.
Old 02-20-2009, 07:22 AM   #5
'91 Shortbox's Avatar
+ 1 with the mothers. Polish completely, and repeat the step 2 or 3 times. It takes a while, but it's worth it. use either soft rags and rotate often, or use a 3-M type buffing pad(s) with a drill. Also, Mothers is petrolium based, so the pads can be used over and over by simply cleaning them out with paint thinner.
Old 02-22-2009, 03:17 PM   #6
I AM CANADIAN
tt85_GM's Avatar
maybe even go as far down as a 1000 or 2000 grit then polish.
any pics yet dngrous?
Old 02-22-2009, 03:58 PM   #7
4x4 v6 blazer
neo71665's Avatar
Fiero covers by any chance?
If your getting them powder coated they should polish them before they coat them so the finish is smoother. My coater even asked me if I wanted them back like they were and cleared.
Old 02-22-2009, 05:43 PM   #8
B JELUS
GET_LOW's Avatar
i never knew you had a project. What is it?
Old 02-22-2009, 06:30 PM   #9
The valve covers are actually in the back seat of my car, which is at my mechanic's house right now.
They're not Fiero covers. I'll see if anyone can guess, once they see them. I'm leaning towards the full polish, and then coating the recessed areas second. Although the tough part is going to be selecting a color to coat them in, but that can be done later after they get polished.
Jordan, my project is a motor swap in my truck. I'm calling it Project Classified, and there won't be very much progress at all until I get a parts car. (Classified because only a very select few people know what it is, and it's getting classier.)
Old 02-22-2009, 06:52 PM   #10
I'm slap happy, bitches!
no way..... you are polishing em, and then using stiff roller to accent the ribs to match the paint of the engine!
thats classy!
Old 02-22-2009, 06:53 PM   #11
paint shop emm, and see!
Old 02-22-2009, 06:56 PM   #12
Yeah, pretty much... I'll see if Misty can do something in PS with them, I suck at graphics work.
Old 02-22-2009, 07:42 PM   #13
B JELUS
GET_LOW's Avatar
FILL ME IN FOOL!
I won't tell!
Old 02-22-2009, 07:44 PM   #14
If you're lucky, and all goes well, it will be at the Oaktown show. If not finished and all installed, it'll be strapped into the bed.
Old 02-22-2009, 07:47 PM   #15
the driveline will be done, maybe not all the body work, or the rear end swap.
BTW, we gotta plan a caddilac run to see if that shit will work.
Old 02-22-2009, 07:51 PM   #16
Even if the cab corners are just cut out and the rust stripped off, it'll at least be started. Without the go-fast goodies, I'm thinking the stock rear will do fine for now...
Will a 91-93 F-bod trans work as well as the 91-93 fox-body? Everything I'm reading online says it's a WC.
Old 02-22-2009, 07:58 PM   #17
if it has a 2 wire speed sensor it will.
Hydraulic clutch?
Old 02-22-2009, 08:01 PM   #18
That's the plan.
Old 02-22-2009, 08:05 PM   #19
Wahoo!!! http://www.skulte.com/T56.html is telling me I could run a T56, as an almost bolt-in swap?
Old 03-01-2009, 07:02 PM   #20
Polishing Guru
samandjen1's Avatar
you need to sand them down to smooth the surface , I start with 320, 400, 600, 1000,1200 red/ brown rouge on a buffer, then white on a buffer both with sewn spiral wheels. then use the mothrers. Here are some pics on my 2. valve cover I just finished took just about 8 hours to do.
Before
After
Old 03-01-2009, 07:03 PM   #21
That looks GOOOD!
Old 03-01-2009, 07:08 PM   #22
Polishing Guru
samandjen1's Avatar
That looks GOOOD!
Thanks
its a lot of elbow grease
Page generated in 0.61583 seconds with 31 queries
[Output: 109.15 Kb. compressed to 100.45 Kb. by saving 8.70 Kb. (7.97%)]
